Hello everyone
Using Version 6.0.0-rc1-dev-107-gb6934bf54
In the Schematics i perform clear Annotation and the programm is hanging, the same happens if i make Reset existing annotations. Keep existing annotations is working fine, previous rc was working.
Thanks.
Make a bug report over at the bugtracker. (Devs do not really read this forum.)
But when you do include a bit more information. Example:
Does this happen do every schematic? (Even one with only one component?)
Does it maybe only affect schematics with hierarchical sheets?
If you have hierarchical sheets, did you start the tool while in the root sheet or in a sub sheet? (Did you select “annotate whole schematic”?)
Also give the full version string you get from help->about->copy version information.
As this is a user forum, the users here can only try to offer a workaround for your problem not a fix. This means there might be a reason to post here but make it clear that you ask for help fixing your problem via a workaround.
Bug in the software
To help the kicad development effort it is suggested to post your bug description over at the bugtracker .
A detailed explanation on how this is done can be found in the report a bug section of the KiCad website.
Another detailed description about h…
eelik
October 2, 2018, 7:48am
#3
Or rather paste the whole thing as it is, not just the version string (which was already given).
system
Closed
December 31, 2018, 7:48am
#4
