Plotting Differential Measurements
Searched the docs but couldn’t find an answer on this. Is there any way in the simulator to plot the voltage difference between two nodes on the chart? For example if I’ve got a circuit containing a BJT transistor with nets named ‘Base’ and ‘Emitter’, I’d like to plot V(Base)-V(Emitter) to plot the Vbe of the transistor.
I’m running KiCad 6.0.0 on MacOS 12.0.1.
Ahh that’s an interesting workaround I hadn’t considered! Thanks.
