I use an LM339 quad comparator, wich is equivalent to LM2901, and used the spice model supplied by texas instruments ti.com.
It turns out one has to redo the pin assignments of the model since that looks like a 5pin single comparator model only.
However when subsequently assigning pins for units A, B, C and D which are of course different, then the assignements for the last unit so edited, overwrite the pin assignements for the other units. That probably makes connections (everything connected to IN- in any of the units gets connected) within the circuit that are not correct or intended.
Is this analysis correct and can it be solved?
Thanks,
Jan
see post
that answers this question.
