I’m running Kicad 6864 BZR on Arch Linux. It is stable for the most part, but every so often I run into a problem where pcbnew will crash when I try to delete a particular segment. So before I go to the effort of compiling a debug build, I thought I’d try to see if anyone here can help.
If I open the kicad_pcb file in a text editor, I can find the segment in question:
(segment (start 132.1182 64.92) (end 132.1183 64.92) (width 0.25) (layer F.Cu) (net 2))
If I manually remove it from the file (and update the “general” settings so that tracks reads 0) or if I delete it in Kicad then pcbnew will crash.
This segment was left over from a previous routing attempt that I wasn’t happy with so I decided to delete it all and start again.
Any thoughts? If someone can even direct me on how to manually edit the file using a text editor, that would be great!
