PCBNew 6.0.1 missing track highlighter?
In PCBNew 5.1.x there was a button, on the right toolbar, that once pushed, could put in evidence the whole track-path.
I used it quite a lot.
With the 6.0.1 there is a button, inthe same place, that is supposed to highlight the “ratstnest”. So I tried to use it,thinking it was the same as the 5.1.x just with another name, but it doesn’t work as I supposed.
Is that button I’m looking for definitely removed, or is it renamed and put somewhere else, please?
The button is removed. To highlight a track (net) there are a few ways:
  1. Ctrl+click on the net object (Cmd+click on Mac)
  2. Use the “highlight net” hotkey (` by default)
  3. Right-click and choose Highlight Net in the Net Tools menu
  4. Right-click the net in the list of nets in the Appearance panel
  5. Select (left-click) the net from the list in the Net Inspector
ok, I find more immediate the Ctrl+Left Click. Thank you so much for your help.
Why did they move this feature away from the immediate, and put it as hidden?
We did not want to keep around the tool where you enter a mode where clicking on things highlights them. Instead we wanted to make it easy to highlight things from any other mode (i.e. when any other tool is active).
