I think I read somewhere before that it’s possible to “auto-finish” a started track in Kicad, but can’t find a shortcut or a menu for it now. Is it possible?
Time to Ctrl-F “finish” in the manual: 20 seconds (including page load)
Time to type a low-effort question: 2 minutes
Wasted time of everyone who reads something that a self-respecting engineer should feel ashamed to ask: priceless
For everything else, there’s Mastercard
And to head off the obvious follow-up gripe: correct, it does seem not to work from the context menu, that’s a bug (that I literally only noticed myself this morning having only ever used the F key): Pcbnew: 'Attempt Finish' doesn't work first time from the context menu (#19560) · Issues · KiCad / KiCad Source Code / kicad · GitLab
Ah thanks, what a great function
… Edit: though the SHIFT+F doesn’t seem to work, or if I don’t understand what SHIFT+F should do…
And it would probably be fantastic if also, why not as an option, to make it auto add a via and continue where it jumps on tough obstacles, then we finally would have a real, new follow-me router ![]()
Wouldn’t that be a flee-from-me router, not follow-me?
Haha, that’s also a good name, but no, it will for sure then really follow you – all the way!
The “flee-from-me router” is actually the topic in this thread: V9-rc1 / latest v8.99 rerouting a "bad" routed track - #30 by TheSwede
Solved? Pls mark for others searching the forum for solutions. Thx ![]()
Never used it but I think Shift + F will try to route a bus type arrangement where you have already selected a number of pads . . .
See if this helps: KiCad 7, Attempt to Finish Selection (Shift+F)
And here:
Ok thanks, interesting, SHIFT+F seems to do at least something in Kicad 8x, but does nothing in 9-rc1/8.99 here. Maybe it will now get developed into perfection, or got forgotten ![]()
works for me in v9 ![]()
Ok then I must have messed it up somehow with my special key commands, once again
Has anyone used it to get good use of it, and made a demo (video)?
Edit: I removed my personal user.hotkeys file and now SHIFT+F works in v9 as well. Thanks for the tip gkeeth.
Tried both the F and Shift+F now, both are very interesting, actually very usable to speed things up.
