OPA627 problem ngspice.dll
I try to simulate a OPA627 with Kicad but I have a problem.
I imported the spice model and put the file in my project folder but when i try to simulate a i have this errors :
No compatibility mode selected!
warning, model type mismatch in line
s_s1 3 4 1 2 _s1
s_s2 3 4 1 2 _s2
s1 esdn vcc esdn vcc esd_sw
s2 esdp vcc esdp vcc esd_sw
s3 vee esdn vee esdn esd_sw
s4 vee esdp vee esdp esd_sw
s1 out vcc out vcc esd_sw
s2 vee out vee out esd_sw
s1 cap_l cap_r sw_ol_opa627 mid ol_sw
Circuit: KiCad schematic
Original line no.: 0, new internal line no.: 468:
Undefined number [temp]
Cannot compute substitute
Copies=328 Evals=498 Placeholders=15 Symbols=57 Errors=2
Numparam expansion errors: Problem with input file.
Error: ngspice.dll cannot recover and awaits to be detached
Note: can’t find init file.
** ngspice-36 shared library
** Creation Date: Dec 30 2021 15:42:05
Error: there aren’t any circuits loaded.
Can you help me to find a solution please ?
It may be necessary to do the following step (setting the compatibility):
Inspect → Simulator → Sim Parameters → Compatibility mode → PSPICE and LTSPICE
Hmmmm…I’m starting to think this maybe should be the default and you have to use the checkbox to disable it instead.
I agree. All simulations seen here, using off the shelve components, will use PSPICE (LTSPICE) compatible models.
This selection is mutually exclusive to using HSPICE process devvelopment kits (PDKs), which is not a KiCad/Eeschema application, but for IC designers only. So no primary problem.
Would you set up a bug (wish list) report?
Ummm…no can do. I don’t have an account and don’t want to set one up for software I never use outside of offering assistance here. Plus, I am on Windows 7 and can’t use KiCad 6. Sorry, I was just throwing out a suggestion simply to see if there was agreement.
