No op amp output voltage during simulation
I tried simulating an LMC6484 op amp in a simple test circuit (inverting input grounded, noninverting input either grounded or tied to VCC+), but the output shows zero volts for the noninverting input tied to VCC+.
Other op amps I’ve tried work ok for this test. Could someone please suggest what might be the problem?
I’m using several op amps and regulators in a complex circuit, and I’ve been first simulating each of the IC components individually to make sure that their SPICE models work.
Thanks!
LMC6484 op amp.zip (1.2 MB)
You already confirmed other opamps are working. I downloaded your project and tried it. But indeed the output is zero volts. Looks like the simulation model is not correct.
The issue is in the LMC648x-quad.lib. The following works:
  • LMC648x quad opamp model
  • filename: LMC648x-quad.lib
  •              1   2    3    4   5    6    7    8    9    10  11   12  13    14
.subckt LMC648xc out1 in1- in1+ vcc in2+ in2- out2 out3 in3- in3+ vee in4+ in4- out4
.include LMC648x.lib
XU1A in1+ in1- vcc vee out1 LMC648x
XU1B in2+ in2- vcc vee out2 LMC648x
XU1C in3+ in3- vcc vee out3 LMC648x
XU1D in4+ in4- vcc vee out4 LMC648x
.ends
Do you spot the differences?
Yes. Being new at ngspice, this is the second time I prefixed a character string with a number (due to typos in this case), will need to be careful with avoiding that in the future.
Thank you!
There is another important issue in ngspice (all spices):
1M is 1 milli (1e-3)
1Meg is 1 mega (1e6)
If you force the output of the opamp to GND with 1 milliOHm, the model will fail or the simulator will bail out.
EDIT: Not so in KiCad/Eeschema/ngspice. See below.
Some time ago I verified that 1M was interpreted as 1Mega Ohm resistor. I assume it has something to do with one of the compatibility modes.
Edit: / addition
Holger (See follow up) is wize, I’m quite a noob at the spice stuff.
Yes, you are right, that 1M is interpreted as 1e6, and 1m as 1e-3. But this is done in Eeschema, not in ngspice, so has nothing to do with compatibility modes.
Good to know and to remember.
