I get the following error message in ngspice when simulating my op-amp with negative feedback audio signal amplifier circuit drawn in KiCad schematic editor, exported netlist to spice.
Did anyone encounter anything similar, and how did you get around it?
Perhaps @holger has some input?
Thanks in advance!
(By the way, it would be great if ngspice .disto and .noise could be integrated in the KiCad simulation user interface!)
** ngspice-40 : Circuit level simulation program
** The U. C. Berkeley CAD Group
** Copyright 1985-1994, Regents of the University of California.
** Copyright 2001-2023, The ngspice team.
** Please get your ngspice manual from Ngspice, the open source Spice circuit simulator - Documentation: manual and control flow
** Please file your bug-reports at Ngspice circuit simulator - Reporting Bugs
** Creation Date: Sat Apr 1 00:00:00 UTC 2023
Note: Compatibility modes selected: ps lt a
Circuit: KiCad schematic
ngspice 79 → op
Reducing trtol to 1 for xspice ‘A’ devices
Doing analysis at TEMP = 27.000000 and TNOM = 27.000000
No. of Data Rows : 1
ngspice 80 → ac dec 10 10 100k
No. of Data Rows : 41
ngspice 81 → plot vdb(Output)
Warning: Missing charsets in String to FontSet conversion
ngspice 82 → noise v(Output) v1 dec 10 10 100k
Internal Error: incomplete CKTunsetup(), this will cause serious problems, please report this issue !
ERROR: fatal error in ngspice, exit(1)
KiCad version info:
Version: 7.99.0-1.20230701gitbcfb6e4.fc37, release build
wxWidgets 3.2.1
FreeType 2.12.1
HarfBuzz 5.2.0
FontConfig 2.14.1
libcurl/7.85.0 OpenSSL/3.0.9 zlib/1.2.12 brotli/1.0.9 libidn2/2.3.4 libpsl/0.21.1 (+libidn2/2.3.3) libssh/0.10.5/openssl/zlib nghttp2/1.51.0
Platform: Fedora release 37 (Thirty Seven), 64 bit, Little endian, wxGTK, KDE, wayland
Date: Jul 1 2023 17:17:57
Boost: 1.78.0
OCC: 7.6.3
Curl: 7.85.0
ngspice: 40
Compiler: GCC 12.3.1 with C++ ABI 1017
