I try to simulate the OPA856, but when I connect the op amp output via 2 series 1pF capacitors to ground, things go very wrong (This is the DC operating point, but also the AC small signal analysis goes wrong):
Somehow it is as though the two capacitors pull the output to ground.
Replacing the 2 series 1pF capacitors with just one 0.5 pF (or 10 pF, …) fixes it.
(The two capacitors were part of a network with resistors in between that I simplified to send to the forum).
Is this a spice bug? Anyone know how to work around it? (while still having my C-R-C output filter)?
sim-opa856.zip (13.9 KB)
Thanks!
Version Info:
Version: 8.0.6-8.0.6-0~ubuntu24.04.1, release build
wxWidgets 3.2.5
FreeType 2.13.3
HarfBuzz 8.3.0
FontConfig 2.15.0
libcurl/8.9.1 OpenSSL/3.3.1 zlib/1.3.1 brotli/1.1.0 zstd/1.5.6 libidn2/2.3.7 libpsl/0.21.2 libssh2/1.11.0 nghttp2/1.62.1 librtmp/2.3 OpenLDAP/2.6.8
Platform: Ubuntu 24.10, 64 bit, Little endian, wxGTK, X11, gnome, wayland
OpenGL: AMD, AMD Radeon Graphics (radeonsi, renoir, LLVM 19.1.0, DRM 3.58, 6.11.0-9-generic), 4.6 (Compatibility Profile) Mesa 24.2.3-1ubuntu1
Date: Oct 14 2024 23:16:15
wxWidgets: 3.2.4 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.83.0
OCC: 7.6.3
Curl: 8.5.0
ngspice: 43
Compiler: GCC 13.2.0 with C++ ABI 1018
