When an IC has multiple devices…
like the NE5532 has 2 OpAmp’s in the package…
OpAmp “A” and OpAmp “B”
For Device “A”
The model text file defines the pins as …
1 - Non-Inverting Input
2 - Inverting Input
3 - Positiev Power Supply
4 - Negative Power Supply
5 - Output
The Kicad NE5532 device “A” shows the pins as …
3 - Non-Inverting Input
2 - Inverting Input
8 - Positiev Power Supply
1 - Output
So for the Alternate Node sequence this works …
3 2 8 4 1
Now the Question:
The Kicad NE5532 device “B” only shows 3 pins…
5 - Non-inverting Input
6 - Inverting Input
7 - Output
So what do I enter into the Alternate Node Squence field for device “B”?
… since the NE5532 model file shows 5 pins including the 2 power supply pins…
which are not present on the Kicad NE5532 “B” part
Thanks for any help.
