Among other benefits (e.g. PSPICE device model compatibility) this version allows running a .control section with ngspice commands right after the simulation. See https://bugs.launchpad.net/kicad/+bug/1788676 for some info on this feature.
I decided to update to ngspice-30 from ngspice-28.
As a reminder, I followed this procedure on Ubuntu-18.04:
FOR THE RECORD (on Linux Ubuntu 18.04)
I first installed the nightly binaries from the Ubuntu ppa by js-reynaud.
Then I downloaded ngspice-30.tar.gz and compiled according to the instructions by holger:
mkdir release
cd release
…/configure --with-ngshared --enable-xspice --enable-cider --enable-openmp --disable-debug CFLAGS="-m64 -O2" LDFLAGS="-m64 -s"
make -j6
sudo make install
Then I changed the pointers to libngspice from the location created by reynaud’s repo to the default installation location from the sources:
This worked on my Ubuntu-18.04 system.
I will have to see if the links are oke after an update from the repo. I will probably have to restore one or more of the symbolic links. I will figure it out when I come to it.
VDMOS device model has been overhauled extensively
I seem to have noticed that the revamped VDMOS model has three terminals, instead of the 4 in the ‘pspice:MNMOS’ library model. So the ‘pspice:MNMOS’ device is no longer working?
I have tested the PowerMOS test for ngspice-28 that was supplied by @holger at the time, but that fails unless I replace the ‘pspice:MNMOS’ with, for example, the ‘Device:Q_NMOS_DGS’ library model. After that minor change I have the 56A drain current, as expected.
I have probably missed something?
Is the ‘.spiceinit’ (containing ‘set ngbehavior=ps’) file still relevant and implemented in ngspice-30?
