I feel like there must be a way to achieve this:
I have an inverter stage - it has 400V, ground and a switch node. The stage uses paralelled MOS that have gate drivers on another board. Standard stuff.
The tricky thing is getting clearances sorted:
I want 2mm clearances between say GND and switch node, and GND and HV,
I would like to keep gate:ground for the low side gate at 0.2mm and gate:switch node for the high side gate, BUT the high side gate must be 2mm clearance from the HV and GND, and the low side gate must be 2mm from the switch node!
Is there some kind of “grouping” functionality I am missing? like I could make a group called “Phase_A_node” and assign that within that group the clearance is 0.2mm but the group as a whole has 2mm.
Apologies if I am missing something well known/obvious. This feels like it must be a problem encountered by every high voltage designer.
With phase node given clearance - the gate traces are now in violation and there is much wasted copper plane and unconnected pins on the MOSFET…
(can’t post more images because I am new here…)
With phase node at 0.2mm clearance - the low side gate traces are then in violation.
You can also use custom rules in combination with a rule area to constrain them to the location of the that area. There is an example for this in the Syntax Help in the dialog where you create the rules.
With the hint and example on the linked page above, I was quickly able to make it generate this automatically, after creating netclasses for each of the phases and the HV bus.
