Multiple components for a single symbol
I am looking for a clean way to have multiple components for a single symbol so when I’m generating the fabrication output my BOM and positions files it will contain all the relevant components.
Examples for where it is needed:
*Raspberry Pi CM5 has two 100 pin connectors. (Requires two components for each symbol)
*Clips shielding like the Harwin system needs to have multiple clips for a single shielding can. (Requires at least 4 components for each symbol)
Is it supported by KiCad without having me injecting the components after exporting my fabrication files?
A similar topic has already been discussed earlier. In general, the approach of using one symbol and several footprints is not quite right for me. In your case, create a component in the form of a module contour for RP5 with reference points for placing connectors and separate connector components and attach the connectors to the module reference points on the board.
