I know this is a question that has been often asked but all date back a few years so I think I am best getting an up to date answer. Can more than one person simultaneously open/edit the kicad libraries in a shared location?
Put all of the libraries into a proper source code control system. Each user should check out the libraries in the usual way. Set all of Kicad’s pointers to the library location. Then whenever someone updates the libraries, they commit the change, and then all of the other users update their local working copies as needed.
No, you cannot have multiple users editing the same files at the same time (for example, by putting the files on a shared network drive) – KiCad will not handle the scenario if both users edit the file and try to save. The solution described by @Andy_P is also what I would recommend.
what sort of a system do I use to do this?
There is some useful info in this FAQ article. It is aimed at KiCad 5 but most still applies in version 6 (the path variables are different but the concepts are the same). Some familiarity with VCS is helpful and subversion or a non-distributed, lockable VCS has some advantages.
Thank you but I am now totally confused.
My impression is that when I want to place a component in KiCad at the least a list of components is loaded the first time but not after that. So I would assume that if a second user were to add a component to one of those libraries the first would never know it existed unless they restarted.
So what happens if both users make an edit to the same library, I guess that is when the real problems will start. So does a policy of only one user editing at a time work?
I see no clear explanation as to how I get KiCad to work with any other tools to manage the libraries. KiCad expects to find the libraries in a certain location, how would Git for example (no idea how it works) change the behaviour of KiCad to stop conflicts.
If no one edits the libraries, would more than one person be able to use them at the same time?
Well, there are at least two issues here:
Editing library files so that two persons/editors/scripts/whatever write to the same file simultaneously. This doesn’t work because whoever saves last wins. Git or some other VCS can help with the symbol libraries because it’s possible to edit two different symbol and merge the changes without a conflict. However, this doesn’t help with one and the same footprint or symbol because there would be conflicts.
Informing all users that something has been changed and reloading the libraries. Indeed, KiCad doesn’t reload the files automatically and doesn’t inform the in any way. The team must use some other way of communication, and each user must reload the libraries.
That’s something for the developers to think about when the library system is enhanced.
So basically the most important thing to avoid is two people editing at once. Next if an edit is made then yes KiCad needs restarting.
I am not clear on what interaction there is between KiCad and the library files. Are they loaded the first time they are needed like putting a symbol in a schematic and only written back if an edit is made?
The libraries listed in the library table are loaded when you start Kicad.
When you place a symbol on the schematic, the symbol is basically copied from the library to the schematic.
Now while it is possible to edit the symbol in place – that is, edit the instance of the symbol on the schematic – that does not change the symbol in the library. The proper way to do this is to open the library editor, change the symbol in the library, and then back in your schematic do an “Update Symbol.” (And then make sure to commit your library change back to the repo.)
I have noticed that if the library changes while Kicad is open, then the next time you go to grab a symbol from that library, you’ll see the new version.
Anyway, all of this is to say that you shouldn’t rely on libraries on a shared network drive or the like. Use a revision control system.
I have no idea how a revision control system is supposed to work. Would this allow access to the libraries by more than one user or is it more about tracking changes and copying the new versions over when available and no users are using the libraries.
Each user has their own copy of the libraries. They do not have their library tables pointing to a shared network resource with the libraries. The last thing you need is to have two or more users trying to edit a file at the same time.
A revision control system requires a repository for the data. Each user who is working on some data in the repository checks out a working copy of those data. When a user is done making changes to the data, they commit those changes back to the repository.
How do other users get your changes? They update their working copies from the repository. Your changes are merged in to their working copies. They make changes and commit them, too, so for you to get those changes, you update your working copy.
So, yes, revision control is about tracking changes. But it’s also very useful for synchronizing those changes.
Now with libraries, there is rarely a need to go back to an older version of something, but the capability is there to do so. Someone made a change to a symbol that nobody likes? You can go back in time, get the previous version, and then make it that the newest version.
And so forth. Revision control is powerful, so it can be confusing.
So is each file replaced with the newer version or is this actually adding changes in the master files to each users files?
A very short and incomplete introduction to git:
Every user has a complete copy of the library, and can do with it as he / she wishes. Add new symbols, change existing ones, delete symbols, etc. Git has a built in system to track all the changes each person makes, but the changes are all local.
At some point, you want to re-synchronize all the changes that those people made, for example, so that a new footprint you made can be used by the rest of the group. To do this, git has a “master” repository that is accessible by everybody in the group. This master should be in a central location that can be accessed by everybody. For example on a website like gitlab. Then, to re-synchronize, you merge the changes you made into the “master”, and the others re-syncronize with the master after that to pull the changes you made.
This should be easy in most situations, If however multiple people have changed the same part (lets take a resistor for example) then conflicts may arise, but git has built-in functions to help with resolving such differences. Git also keeps track of when changes were made, who made the changes and exactly what was changed each time.
To experiment a bit with this, you can for example have a look at a website like Wikipedia. (Which also uses git). If you press the View History button of any Wikipedia article:
then you can select any two older versions (the green dots at 1. and 2.) and then in step 3, press Compare selected revisions
In this way Wikipedia can let anybody make changes. Certain people are alerted if changes are made, and if they don’t like the changes you made, it’s simply reverted. (Wikipedia also has special methods for dealing with vandalism, politically sensitive topics and other sorts of problems, but the default is that anybody can make a change to an article.
Git was originally designed to work with source code for programs, but it works quite good with anything that is text based. This leaves te problem with graphic stuff such as schematics in KiCad. Although the files are are text-based, it’s hard to interpret by humand. For this there are helper programs that can make the differences visual in a graphical way. For this, see for example:
Visual Schematic Diffs In KiCAD Help Find Changes | Hackaday
There are a lot of different VCS (Version Control systems) and Git has become quite popular since it’s introduction in Git - Wikipedia It’s one of the most successful Open source projects and was started by Linus himself.
To get back to:
With Git, each user has a local copy of the complete history, and is free to do with it whatever they want on their own PC. It’s quite easy to “check out” an old version of a library, for example if you have to make some changes to a project you did for some customer long ago.
KiCad itself, and the KiCad libraries are also all put into git repositories, and hosted on gitlab Gitlab has also built a lot of services around git, such as a chat system in which users can communicate with each other such as filing bug reports or announcing when issues are fixed.
This is just a general description of a part of what git can do. Many books and websites have been written about it and you should do some reading there if this topic interests you.
Because of all this, git is also a “backup system on steroids”. You can make some wild changes to your PCB, and if it turns out to be a bad change, then you simply revert to a version from before you did something *&^%$#@! If you have synchronized the git database with some external location, then even your whole PC may crash or your house with everything in it may burn down, but your project is still easy to recover.
Right it’s starting to make sense. So is anything installed on the server or does the desktop client handle everything? I only see one download. Once I have a desktop client do I need to install something on the central server if say we use the work server or other online hosting?
Looks like I have a 500 page book to read about it .
You have to install git itself on the server, and on any system you want to work with git.
Git is very flexible, it can use SSH, http and a bunch of other methods for data transfers.
If you want to go really dumb, you can manually copy a git repository to an USB stick (file server, whatever) and at a later time or other location copy it again. However, for this does cripple git a bit because an important part of git is to track which user makes each change to the database, and this gets damaged if you do this.
If you are able to setup a server connected to the Internet and install and configure git and SSH then you already have a solid base to work with. Alternatively, you can get a free account on gitlab. The main limitations for a free account on gitlab is that it’s only for open source projects (so viewable by everybody) and you have some data limits.
When you want to learn to apply git effectively, there is a bit of a learning curve ahead of you though.
So is the same software used on clients and servers?
Generally yes. When you clone a git repo, the full copy of the repo is populated in your workspace .git
directory.
But typically on the “server” you run a wrapper around Git like Gitlab, Gitea, Github, etc that manages user access and provides a nice web UI to your Git repo on the server.
I highly recommend Gitlab for getting started. Their free tier is generous. If you want to run your own server, then use Gitea.
One other things to remember with Git – you should close KiCad before updating your local files (git pull
Some thoughts on collaboration and how Git fits into modern workflow:
It works fairly well to store KiCad files in Git because they are a simple ASCII format with plenty of line feeds. So if two people modify the same library, it typically merges OK unless they modify the same part.
Oh so I am back to confused again. Ideally we get it setup on our local server and on our machines. Maybe our IT people know more about git and can help as I can’t even install a program without them anyway.
Great an account and group (for your organization) at Gitlab, then create a repo in Gitlab.
If you are running Linux/MACOS, then just install git and use the git command line client.
If you are running windows, install:
- https://gitforwindows.org/ (provides Git command line interface, and is needed by Tortoise Git)
- https://tortoisegit.org/ (provides UI in windows explorer – right click on directories/files to do Git operations)
Then in Windows explore, select the Tortoise Git clone option and use the URL from the Gitlab repo.
Now you can pull/push changes to the repo from your local workspace.
The advantage of hosting your repo on Gitlab is you can access from anywhere in the world and you don’t have to run your own Git server. Some don’t think this is secure enough, but if HTTPS is secure enough for your bank, it is probably secure enough for your design files.
If cloud hosting is not acceptable, then it is not hard to set up a Gitea server.
