I’m trying to get Monte Carlo analysis of filters to work. A basic .AC analysis works fine, but I can’t get a script to work to run a sizeable iteration count and collect output.
Here’s the SPICE netlist generated (the blockquote unfortunately seems to not format correct). The .ac directive before .control and the loop is for KiCAD to understand this is an .AC analysis. Otherwise it just issues an error when I try to run it.
.title KiCad schematic
R1 Net-C2-Pad1 Net-C1-Pad1 1000
R2 Net-C2-Pad2 Net-C1-Pad1 90.9
R3 Net-C1-Pad1 VIN 100
C1 Net-C1-Pad1 0 76.9nF
C2 Net-C2-Pad1 Net-C2-Pad2 6.83nF
X1 0 Net-C2-Pad2 VDD VSS Net-C2-Pad1 IDEAL
R4 Net-C4-Pad1 Net-C3-Pad1 1000
R5 Net-C4-Pad2 Net-C3-Pad1 500
R6 Net-C3-Pad1 Net-C2-Pad1 1000
C3 Net-C3-Pad1 0 15.0nF
C4 Net-C4-Pad1 Net-C4-Pad2 5.99nF
X2 0 Net-C4-Pad2 VDD VSS Net-C4-Pad1 IDEAL
R7 Net-C6-Pad1 Net-C5-Pad1 1000
R8 Net-C6-Pad2 Net-C5-Pad1 500
R9 Net-C5-Pad1 Net-C4-Pad1 1000
C5 Net-C5-Pad1 0 17.9nF
C6 Net-C6-Pad1 Net-C6-Pad2 4.42nF
X3 0 Net-C6-Pad2 VDD VSS Net-C6-Pad1 IDEAL
R10 VOUT Net-C7-Pad1 1000
R11 Net-C8-Pad2 Net-C7-Pad1 500
R12 Net-C7-Pad1 Net-C6-Pad1 1000
C7 Net-C7-Pad1 0 27.5nF
C8 VOUT Net-C8-Pad2 2.29nF
X4 0 Net-C8-Pad2 VDD VSS VOUT IDEAL
V1 VDD 0 dc 15
V2 0 VSS dc 15
V3 Net-R100-Pad2 0 dc 0 ac 1 0 sin(0 1 12.5k 0 0)
R100 VIN Net-R100-Pad2 0
R101 VOUT 0 100k
… removed ATr1 through ATr102 since the annoying forumware thinks I’m trying to reference other users rather than simply insert a text block and refuses to accept it …
.save V(0)
.save V(GND)
.save V(Net-C1-Pad1)
.save V(Net-C2-Pad1)
.save V(Net-C2-Pad2)
.save V(Net-C3-Pad1)
.save V(Net-C4-Pad1)
.save V(Net-C4-Pad2)
.save V(Net-C5-Pad1)
.save V(Net-C6-Pad1)
.save V(Net-C6-Pad2)
.save V(Net-C7-Pad1)
.save V(Net-C8-Pad2)
.save V(Net-R100-Pad2)
.save V(VDD)
.save V(VIN)
.save V(VOUT)
.save V(VSS)
.subckt IDEAL 1 2 3 4 5
E1 5 0 1 2 1000000.0
.ends
.ac dec 10 10 1000000.0
.control
let mc_runs = 100
let run = 1
- set curplot = new
set scratch = $curplot
define tolerance(val, pct) (val + val * (pct/100) * sunif(0))
dowhile run <= mc_runs
alter C1 = tolerance(76.9n, 5)
alter C2 = tolerance(6.83n, 5)
alter C3 = tolerance(15.0n, 5)
alter C4 = tolerance(5.99n, 5)
alter C5 = tolerance(17.9n, 5)
alter C6 = tolerance(4.42n, 5)
alter C7 = tolerance(27.5n, 5)
alter C8 = tolerance(2.29n, 5)
alter R1 = tolerance(1000, 2)
alter R10 = tolerance(1000, 2)
alter R100 = tolerance(0, 2)
alter R101 = tolerance(100k, 2)
alter R11 = tolerance(500, 2)
alter R12 = tolerance(1000, 2)
alter R2 = tolerance(90.9, 2)
alter R3 = tolerance(100, 2)
alter R4 = tolerance(1000, 2)
alter R5 = tolerance(500, 2)
alter R6 = tolerance(1000, 2)
alter R7 = tolerance(1000, 2)
alter R8 = tolerance(500, 2)
alter R9 = tolerance(1000, 2)
set run = “$&run”
set dt = $curplot
setplot $scratch
let vout{$run}={$dt}.v(out)
setplot $dt
let run = run + 1
end
plot db({$scratch}.all)
.endc
.end
The code is almost verbatim from an example bundled with ngspice-28, in examples/Monte_Carlo/MonteCarlo.sp
It does run for a while, about 5 seconds on my MacBook Pro, so it’s clearly doing something apart from spitting out errors.
The console output is:
Circuit: KiCad schematic
Doing analysis at TEMP = 27.000000 and TNOM = 27.000000
Reference value : 1.00000e+01No. of Data Rows : 51
Error: no such function as ac304.v.
Error: no such function as ac305.v.
Error: no such function as ac306.v.
Error: no such function as ac307.v.
Error: no such function as ac308.v.
Error: no such function as ac309.v.
Error: no such function as ac310.v.
Error: no such function as ac311.v.
Error: no such function as ac312.v.
Error: no such function as ac313.v.
Error: no such function as ac314.v.
Error: no such function as ac315.v.
Error: no such function as ac316.v.
Error: no such function as ac317.v.
Error: no such function as ac318.v.
Error: no such function as ac319.v.
Error: no such function as ac320.v.
Error: no such function as ac321.v.
Error: no such function as ac322.v.
Error: no such function as ac323.v.
Error: no such function as ac324.v.
Error: no such function as ac325.v.
Error: no such function as ac326.v.
Error: no such function as ac327.v.
Error: no such function as ac328.v.
Error: no such function as ac329.v.
Error: no such function as ac330.v.
Error: no such function as ac331.v.
Error: no such function as ac332.v.
Error: no such function as ac333.v.
Error: no such function as ac334.v.
Error: no such function as ac335.v.
Error: no such function as ac336.v.
Error: no such function as ac337.v.
Error: no such function as ac338.v.
Error: no such function as ac339.v.
Error: no such function as ac340.v.
Error: no such function as ac341.v.
Error: no such function as ac342.v.
Error: no such function as ac343.v.
Error: no such function as ac344.v.
Error: no such function as ac345.v.
Error: no such function as ac346.v.
Error: no such function as ac347.v.
Error: no such function as ac348.v.
Error: no such function as ac349.v.
Error: no such function as ac350.v.
Error: no such function as ac351.v.
Error: no such function as ac352.v.
Error: no such function as ac353.v.
Error: no such function as ac354.v.
Error: no such function as ac355.v.
Error: no such function as ac356.v.
Error: no such function as ac357.v.
Error: no such function as ac358.v.
Error: no such function as ac359.v.
Error: no such function as ac360.v.
Error: no such function as ac361.v.
Error: no such function as ac362.v.
Error: no such function as ac363.v.
Error: no such function as ac364.v.
Error: no such function as ac365.v.
Error: no such function as ac366.v.
Error: no such function as ac367.v.
Error: no such function as ac368.v.
Error: no such function as ac369.v.
Error: no such function as ac370.v.
Error: no such function as ac371.v.
Error: no such function as ac372.v.
Error: no such function as ac373.v.
Error: no such function as ac374.v.
Error: no such function as ac375.v.
Error: no such function as ac376.v.
Error: no such function as ac377.v.
Error: no such function as ac378.v.
Error: no such function as ac379.v.
Error: no such function as ac380.v.
Error: no such function as ac381.v.
Error: no such function as ac382.v.
Error: no such function as ac383.v.
Error: no such function as ac384.v.
Error: no such function as ac385.v.
Error: no such function as ac386.v.
Error: no such function as ac387.v.
Error: no such function as ac388.v.
Error: no such function as ac389.v.
Error: no such function as ac390.v.
Error: no such function as ac391.v.
Error: no such function as ac392.v.
Error: no such function as ac393.v.
Error: no such function as ac394.v.
Error: no such function as ac395.v.
Error: no such function as ac396.v.
Error: no such function as ac397.v.
Error: no such function as ac398.v.
Error: no such function as ac399.v.
Error: no such function as ac400.v.
Error: no such function as ac401.v.
Error: no such function as ac402.v.
Error: no such function as ac403.v.
Error: no such vector @c1[i]
I can’t really tell what the problem here is… if it’s simply a matter of integrating with KiCAD, if KiCAD doesn’t know how to obtain the plot data. Or if the example is broken. (I built ngspice as a shared object so don’t have the command line to experiment with and I’m afraid building and installing a command line version will nuke the shared object installed.)
Why is it looking for “@c1[i]”?!
