Making double sided PCB vias using fibre laser
Hi Everyone,
I managed to work out how to do make double sided PCB vias using fibre laser.
Initially I wanted a plugin to generate files for procedure, but I managed to find work around for every issue such that it should be possible to make doubled sided PCB with connected vias using fibre laser.
Documented here - Making double sided PCB vias with fibre laser
If someone could try and confirm it can work I am thrilled. :smiley: My fibre laser is out of action at the moment. It is a big gain if it works - double sided PCBs with vias in hours. :grinning: Shorten time to get working PCBs into manufacturing. Good too if a plugin can be developed to create the required files directly. :smile:
So why did you start a new thread?
The other thread focused with software plugin may be using a little bit of AI to get some python code written. This thread more to do with manufacturing and refining process. I can do the fibre laser tests myself but my fibre laser out of action for now (may be weeks).
