I was putting together a circuit and decided I need to use some Diode Logic, specifically an OR. NOt a problem they are very simple. If I was to make a habit of it it could get tedious in layout, so I decided to create a custom symbol and footprint.
It all works fine even autoroutes with freerouter but it is not perfect. The Diodes and Capacitor will not show up in the BOM or get device numbers of their own. No values/types can be assigned to them. While it is fine for what I’m doing would it be a worthwhile addition to have a better system for this kind of thing? Probaley a lot of work for very little gain.
Yes I did something similar for a chain of LEDs which I wanted to slant the whole row at a precise angle (7 segment display). Since it was for hand assembly I didn’t mind. As pointed out there are ongoing discussions on the concept in other threads.
