Would it be possible to have an updated list based on the current nightly codebase?
Or perhaps there is an easy way to search for built-in text variables in the code?
This may be off topic. Is there a way to expand these values on the command line? for example, run “kicad -E ${schematic_version}” get the schematic_version. by this you will be able to define a variable in kicad and use it both in and out of kicad. Thanks.
System variables for symbol text: REFERENCE VALUE FOOTPRINT FOOTPRINT_LIBRARY FOOTPRINT_NAME DATASHEET SYMBOL_LIBRARY SYMBOL_NAME SYMBOL_DESCRIPTION SYMBOL_KEYWORDS UNIT
user-defined fields by name
System variables for label text: CONNECTION_TYPE (global labels, hierarchical labels and sheet pins only) SHORT_NET_NAME NET_NAME NET_CLASS INTERSHEET_REFS (global labels only)
System variables for sheet text: # (sheet number) ## (sheet count) SHEETPATH SHEETNAME SHEETFILENAME
System variables for schematic text: # (sheet number) ## (sheet count) SHEETPATH SHEETNAME FILENAME PROJECTNAME
System variables for footprint text: REFERENCE VALUE LAYER FOOTPRINT_LIBRARY FOOTPRINT_NAME
associated symbol’s fields by name
System variables for PCB text: LAYER
System variables for worksheet text: KICAD_VERSION # (sheet number) ## (sheet count) SHEETNAME FILENAME PAPER LAYER ISSUE_DATE REVISION TITLE COMPANY COMMENT0, COMMENT1 … COMMENT9
You can also search the code for ::ResolveTextVar.
System variables for symbol text: REFERENCE VALUE FOOTPRINT FOOTPRINT_LIBRARY FOOTPRINT_NAME DATASHEET SYMBOL_LIBRARY SYMBOL_NAME SYMBOL_DESCRIPTION SYMBOL_KEYWORDS UNIT EXCLUDED_FROM_BOM EXCLUDED_FROM_BOARD
System variables for footprint text: REFERENCE VALUE LAYER FOOTPRINT_LIBRARY FOOTPRINT_NAME NET_NAME(<pad number>) NET_CLASS(<pad number>) PIN_NAME(<pad number>)
Do we have a variable yet for the current date/time to put on schematic title blocks? Issue date is blank until it is issued, but I print a schematic periodically as I design a board, and really miss the date/time-printed that eagle provided.
