The first of the KiCon 2023 videos is available now at https://www.youtube.com/watch?v=4qbjNLV-h14
We’ll be releasing further talks regularly and will post updates here
@craftyjon’s presentation on Database Libraries is now available at https://www.youtube.com/watch?v=nZqoay-Yevk
@seth_h’s presentation on Footprint and 3D model generation is now available at https://youtu.be/hpkzoAAmWJY
(Edit: Added Index, paulvdh)
00:00 Introduction of speaker Seth Hillbrand.
00:55 Ad-hoc talk because of last minute cancellation because of visa problems.
02:05 Footprint wizard to make a custom footprint.
05:02 KiCad Footprint Generator (Librarian tool, scripted approach).
07:34 git clone KiCad / KiCad Libraries / KiCad Footprint Generator · GitLab
08:50 Setup for kicad-footprint-generator.
13:55 Making a merge request.
15:32 3D models.
16:25 Scaled cube (simple)
17:25 Other sources, such as SnapEDA.
18:00 Creating your own 3D model
18:03 https://www.gitlab.com/kicd/libraries/kicad-packages3D-generator
21:20 generator.py
22:20 Running the generator.py script.
22:55 Use FreeCAD to verify the genrated footprint is correct.
23:50 Check if the 3D model fits on the footprint.
24:03 Questions?|
24:50 What about adding a button in KiCad to automate the merge request?
26:20 Is a merge request for the YAML file sufficient, or do you wish merge requests for more?
27:44 Requirements for branches for making a merge request? (Make your own branch).
29:30 Add pictures (screenshot?) for easier verification.
29:55 Make sure your branch is clean. (Separate branch only for a single footprint merge request).
31:02 Pin 1 indicator was in the wrong corner. (Fix it by editing the YAML file.)
31:50 Are there plans to unify the Footprint Wizards with the Footprint Generator scripts?
3 posts were split to a new topic: Cancelled ECAD/MCAD Talk
A post was split to a new topic: How do I setup a Data Base?
A post was split to a new topic: FPGA Autogeneration
Andrew Whyte’s presentation on diffgerber is now available at https://www.youtube.com/watch?v=PAm65BVg834
@Qbort’s presentation on migrating libraries and designs to KiCad is now available at https://youtu.be/UouWuxlt9Uk?si=oqbi05eNmQGyS_Zr
Are there more videos in the pipeline?
Are there any other platforms, like Odysee or your own server, where the Videos are uploaded?
Is there any chance the presentation “InvenTree is not a database” will be available as a video?
