I’ve posted my question in the electrical engineering stack exchange (Easier to upload pictures there):
I’m able to simulate a simple circuit with a voltage source. When I try to use a pulsed voltage, the netlist generation fails. Is this a known problem?
That’s what I would expect, but KiCad doesn’t generate the right net list, for some reason reason it deletes the node entries. I’ll post my exact version.
kicad version: 5.1.1 release build
platform: linux 5.0.6-arch1-1-ARCH x86_64
ngspice-30
Can somebody reproduce this? It happens with all the different voltage source options, pulse, sine, etc. The generated netlist doesn’t include the node1 and node2.
I reproduced this on 5.1.1 on Ubuntu. The voltage source(pulse) is not netlisting correctly. I’ll dig in a little and see what I can figure out. If it is a bug I’ll submit a bug report.
Hmmm. Saved the schematic, then reopened at home. Different machine but same versions of Ubuntu and KiCad. It now netlists correctly. I’ll experiment some more.
I just tried this with my Windows 7 & KiCad 5.0.2. Step #6 resulted in a correct netlist and upon Step #8 it did not throw any error. Could be either an Ubuntu or KiCad 5.1.1 problem. Maybe it’s time to move this over to the bug tracker since you can now consistently recreate on your end?
@jgroves9 are you using 5.1.1? There is a bug that causes this symptom that is fixed in 5.1.2. If you see this message in 5.1.2 please open a bug report
