Kicad Spice error model not found
Hello, I am trying to include component AD8561 into my KiCAD 5 spice simulation, however I get the error:
s.xu1.s1 xu1.10 xu1.11 j3-2 j3-2 slatch1
Unable to find definition of model slatch1 - default assumed
Reducing trtol to 1 for xspice 'A' devices
Does anyone have a hint how to solve the problem?
I downloaded the SPICE model from this link
and the Kicad Symbol from this other link.
The component can be inserted into a schematics, but when running simulation, it stops at first iteration.
The same happens if I try to insert AD8001, then I get this error:
Too many parameters for subcircuit type "ad8001a" (instance: xxu1)
Error: there aren't any circuits loaded.
Any help is welcome.
Thanks.
I figured it out. It was a syntax problem of the file provided by AnalogDevices, programmed in PSPICE, that does not cope well with ngspice 26 (the one that KiCAD 5 uses).
The solution was to upgrade to git master branch of ngspice 28 (at least patch of Jul 25 2018)
See https://sourceforge.net/p/ngspice/discussion/133842/thread/286a096d/
Ngspice-28 for KiCad
