I noticed that pip is distributed both with stable and dev releases of kicad…
but I tried to use pip to install a python module both in kicad stable and latest dev without succeed…
is pip functionality working for kicad in windows?
thx
Maurice
thx
Maurice
@nickoe
I was trying to install through pip a library useful for Via Fence stitching
Particularly the module is
pyclipper
(an other option would be to just add pyclipper to win distribution)
thanks for having a look at it
Maurice
Did you check the pip installation itself… I think there was an option to update it?
yes, already tested with
python -m pip install --upgrade pip
still I cannot install pyclipper
hm… and pyclipper can be installed in run-of-the-mill python installations with pip?
PS: I’m sure you already tried that, it’s just me doodeling around on my keyboard before going to bed
PPS: … while watching an IoT project of mine going bonkerz and not doing what it’s supposed to around this time of the day. Damnit, now I have to lower that 12m aluminium mast tomorrow… sad.
no way…
I’m going to try to install pyclipper in my building mingw chain… that could work
EDIT
bingo! that is working! Now I can add python modules to my win kicad installation… very unfriendly that the standard distro cannot use pip directly…
M
EDIT2
also this trick unfortunately is not working for numpy!
It is supposed to work, but I am not sure if does so or not. From which console do you install it?
I just launch the Command Prompt
and then for example:
cd %programfiles%\Kicad\bin
pip install pyclipper
Do you think it would help if you posted the error messages?
here it is
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\Users\userC>cd %programfiles%\Kicad\bin
C:\Program Files\KiCad\bin>pip install pyclipper
Collecting pyclipper
Using cached pyclipper-1.0.6.zip
Complete output from command python setup.py egg_info:
Download error on https://pypi.python.org/simple/setuptools_scm_git_archive/: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661) – Some packages may not be found!
Download error on https://pypi.python.org/simple/setuptools-scm-git-archive/: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661) – Some packages may not be found!
Couldn’t find index page for ‘setuptools_scm_git_archive’ (maybe misspelled?)
Download error on https://pypi.python.org/simple/: [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed (_ssl.c:661) – Some packages may not be found!
No local packages or working download links found for setuptools_scm_git_archive>=1.0
Distribution mode: Compiling Cython generated .cpp sources.
Traceback (most recent call last):
File “”, line 1, in
File “c:\users\userc\appdata\local\temp\pip-build-rvhaub\pyclipper\setup.py”, line 91, in
cmdclass=cmdclass,
File “C:\Program Files\KiCad\lib\python2.7/distutils/core.py”, line 111, in setup
_setup_distribution = dist = klass(attrs)
File “C:\Program Files\KiCad\lib\python2.7\site-packages/setuptools/dist.py”, line 316, in init
self.fetch_build_eggs(attrs[‘setup_requires’])
File “C:\Program Files\KiCad\lib\python2.7\site-packages/setuptools/dist.py”, line 371, in fetch_build_eggs
replace_conflicting=True,
File “C:\Program Files\KiCad\lib\python2.7\site-packages/pkg_resources/init.py”, line 846, in resolve
dist = best[req.key] = env.best_match(req, ws, installer)
File “C:\Program Files\KiCad\lib\python2.7\site-packages/pkg_resources/init.py”, line 1118, in best_match
return self.obtain(req, installer)
File “C:\Program Files\KiCad\lib\python2.7\site-packages/pkg_resources/init.py”, line 1130, in obtain
return installer(requirement)
File “C:\Program Files\KiCad\lib\python2.7\site-packages/setuptools/dist.py”, line 439, in fetch_build_egg
return cmd.easy_install(req)
File “C:\Program Files\KiCad\lib\python2.7\site-packages/setuptools/command/easy_install.py”, line 659, in easy_install
raise DistutilsError(msg)
distutils.errors.DistutilsError: Could not find suitable distribution for Requirement.parse(‘setuptools_scm_git_archive>=1.0’)
----------------------------------------Command “python setup.py egg_info” failed with error code 1 in c:\users\userc\appdata\local\temp\pip-build-rvhaub\pyclipper\
but you should be able to replicate it just launching the command I posted
It looks like setuptools_scm_git_archive requires Python 3, although pyclipper claims to work with 2.7.
KiCad is python 2.7. I would raise an issue on pyclipper github, I don’t think it is a KiCad issue.
not really,
I can build and use pyclipper.pyc, as I pointed out before, using my building chain for kicad in python 2.7.11
So this is an issue in kicad pip installation structure
Hmm, yes I think you are right. I tried installing pyclipper into my system python2.7 and it worked fine.
My next hunch is something to do with SSL certificates.
Could you try pip install --cert …\ssl\certs\ca-bundle.crt pyclipper ?
C:\Program Files\KiCad\bin>pip install --cert ..\ssl\certs\ca-bundle.crt pyclipper
File “”, line 1, in
File “c:\users\userc\appdata\local\temp\pip-build-wj3he3\pyclipper\setup.py”, line 91, in
cmdclass=cmdclass,
----------------------------------------Command “python setup.py egg_info” failed with error code 1 in c:\users\userc\appdata\local\temp\pip-build-wj3he3\pyclipper\
I don’t know how pip works, please let me know if you find a way to fix this.
I know this is really late but prepare for some grade A some thread necromancy.
I’ve got pip working in KiCad by starting a BoM generator script, editing the command given in the dialog to be
pip install <package>
running it and changing it back to the command when done.
Sounds like this could be it’s own script “pipkicad.” Is there a way you could create it or provide enough details for someone else to trivially create it?
Well, I gave it a try with @maui command and it still fails, however, it does look very promising. Thanks @ben_waese-perlman
Run command:
Command error. Return code 1
Info messages:
Downloading https://files.pythonhosted.org/packages/fc/65/8fff10c463f1f60ea8ec9fbb3e592636d0b259fb25bbe2ace3c050c6471e/pyclipper-1.1.0.post3.zip (138kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'error'
Error messages:
DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7. More details about Python 2 support in pip, can be found at https://pip.pypa.io/en/latest/development/release-process/#python-2-support
ERROR: Command errored out with exit status 1:
command: 'C:/Program Files/KiCad_v5_1_6/bin/python.exe' 'C:\Program Files\KiCad_v5_1_6\lib\python2.7\site-packages\pep517\_in_process.py' get_requires_for_build_wheel 'c:\users\***\appdata\local\temp\tmpggacgg'
cwd: c:\users\***\appdata\local\temp\pip-install-dzieki\pyclipper
Complete output (4 lines):
File "C:\Program Files\KiCad_v5_1_6\lib\python2.7\site-packages\pep517\_in_process.py", line 22, in <module>
import compat
ImportError: No module named compat
ERROR: Command errored out with exit status 1: 'C:/Program Files/KiCad_v5_1_6/bin/python.exe' 'C:\Program Files\KiCad_v5_1_6\lib\python2.7\site-packages\pep517\_in_process.py' get_requires_for_build_wheel 'c:\users\***\appdata\local\temp\tmpggacgg' Check the logs for full command output.
just for kicks, here is the version:
pip --version
Success
Info messages:
pip 19.2.3 from C:\Program Files\KiCad_v5_1_6\lib\python2.7\site-packages\pip (python 2.7)
and the KiCAD version:
Application: Eeschema
Version: (5.1.6)-1, release build
wxWidgets 3.0.4
libcurl/7.66.0 OpenSSL/1.1.1d (Schannel) zlib/1.2.11 brotli/1.0.7 libidn2/2.2.0 libpsl/0.21.0 (+libidn2/2.1.1) nghttp2/1.39.2
Boost: 1.71.0
Curl: 7.66.0
Compiler: GCC 9.2.0 with C++ ABI 1013
USE_WX_GRAPHICS_CONTEXT=OFF
USE_WX_OVERLAY=OFF
KICAD_SCRIPTING=ON
KICAD_SCRIPTING_MODULES=ON
KICAD_SCRIPTING_PYTHON3=OFF
KICAD_SCRIPTING_WXPYTHON=ON
BUILD_GITHUB_PLUGIN=ON
KICAD_USE_OCE=ON
KICAD_USE_OCC=OFF
KICAD_SPICE=ON
Just change the command of any of the BOM tools or make a new one:
Well, this is going to be a problem…
Run command:
python -m pip install -U pip
Info messages:
Collecting pip
Downloading https://files.pythonhosted.org/packages/43/84/23ed6a1796480a6f1a2d38f2802901d078266bda38388954d01d3f2e821d/pip-20.1.1-py2.py3-none-any.whl (1.5MB)
Installing collected packages: pip
Found existing installation: pip 19.2.3
Uninstalling pip-19.2.3:
Error messages:
ERROR: Could not install packages due to an EnvironmentError: [Error 5] Zugriff verweigert: 'c:\\program files\\kicad_v5_1_6\\bin\\pip-script.py'
Consider using the `--user` option or check the permissions.
