recently on Ubuntu/Mint 20 FreeCAD daily (nightly) has switched to OCC 7.5.1 (previously it was on OCC 7.3)
This is creating an issue with KiCAD-nightly which relies on OCC 7.3
Would it be possible to build the KiCAD debian package on OCC 7.5 as to allow the coexistence of both sw?
here the FreeCAD PPA:
Wasnāt @tijuca somehow involved with the packing of KiCAD on Ubuntu ? (sorry if I misremembered)
No, Iāve nothing to do with Ubuntu and their packaging. Iām (only) maintaining the Debian packages of KiCad.
Sorry I got confused, anyway thank you for your time and effort!
@jsreynaud packages the Ubuntu nightlies.
It looks like libocct-* are not packaged for 7.5.1 on Ubuntu Focal (only 7.3) so Iām confused how FreeCAD has changed?
FreeCAD builds their own PPA for libocct. We use their PPA for Xenial and Bionic where OCC was not packaged for Ubuntu.
If we also used it for Focal and Groovy, it would force uninstall the stable KiCad packaged with the distros (5.1.5 & 5.1.6) because OCC 7.5.1 and 7.3 are mutually exclusive. We could potentially require users to also use the PPA for stable KiCad but first Jean-Samuel is checking to see how hard it would be to add version+ (i.e. >=7.3) dependencies instead.
Hey Folks, there should be some new nightlies up with the OCC logic for both 7.3 or 7.5. Please try them out and let us know if it is still not working
Hi @Seth_h
Iāve just checked and still I cannot install k-nightly.
Here my commands:
sudo add-apt-repository ppa:kicad/kicad-dev-nightly
sudo apt update
sudo apt install kicad-nightly
here the errors:
Reading package lists⦠Done
Building dependency tree
Reading state information⦠Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:The following packages have unmet dependencies:
kicad-nightly : Depends: libocct-data-exchange-7.3 but it is not going to be installed
Depends: libocct-foundation-7.3 but it is not going to be installed
Depends: libocct-modeling-algorithms-7.3 but it is not going to be installed
Depends: libocct-modeling-data-7.3 but it is not going to be installed
Depends: libocct-ocaf-7.3 but it is not going to be installed
Recommends: kicad-nightly-doc-en but it is not installable
E: Unable to correct problems, you have held broken packages.
Is there a way to specify to install k-nightly using OCC 7.5 libs?
Iām on:
āLinux Mint 20.1, code-name āUlyssaā. It includes Linux Kernel 5.4, based on Ubuntu 20.04ā
I get the same error
Hmm⦠We may have skipped yesterdayās build. I see the amd64 deb is still trying to build. Says it should be done in another couple of hours. Once the build (https://launchpad.net/~kicad/+archive/ubuntu/kicad-dev-nightly/+build/21177970) finishes, can you please try again?
All thanks go to @jsreynaud for figuring this out! Glad it is fixed for you
Iām still busted with a variant of whatās described above and wondering if itās related. Without freecad daily installed, I canāt install nightly. This is on a freshly installed Ubuntu 20.10 after adding the ppa per instructions.
$ sudo apt install kicad-nightly
kicad-nightly : Depends: libocct-modeling-algorithms-7.3 but it is not installable or
libocct-modeling-algorithms-7.5 but it is not installable
Depends: libocct-modeling-data-7.3 but it is not installable or
libocct-modeling-data-7.5 but it is not installable
Depends: libocct-data-exchange-7.3 but it is not installable or
libocct-data-exchange-7.5 but it is not installable
Depends: libocct-visualization-7.3 but it is not installable or
libocct-visualization-7.5 but it is not installable
Depends: libocct-foundation-7.3 but it is not installable or
libocct-foundation-7.5 but it is not installable
Depends: libocct-ocaf-7.3 but it is not installable or
libocct-ocaf-7.5 but it is not installable
Recommends: kicad-nightly-libraries but it is not going to be installed
Is this related to the same issue for resolving the conflict with freecad daily (which I havenāt installed yet on this machine, but will be in the future)? This all seems to have gotten wedged a couple of days ago.
How do I fix this? Please teach me to fish if this is something I can address on my end.
Update:
Installing FreeCAD-daily changes this to the following:
libocct-data-exchange-7.5 : Breaks: libocct-data-exchange-7.4 but 7.4.1+dfsg1-2 is to be installed
libocct-foundation-7.5 : Breaks: libocct-foundation-7.4 but 7.4.1+dfsg1-2 is to be installed
libocct-modeling-algorithms-7.5 : Breaks: libocct-modeling-algorithms-7.4 but 7.4.1+dfsg1-2 is to be installed
libocct-modeling-data-7.5 : Breaks: libocct-modeling-data-7.4 but 7.4.1+dfsg1-2 is to be installed
libocct-ocaf-7.5 : Breaks: libocct-ocaf-7.4 but 7.4.1+dfsg1-2 is to be installed
libocct-visualization-7.5 : Breaks: libocct-visualization-7.4 but 7.4.1+dfsg1-2 is to be installed
On https://launchpad.net/~kicad/+archive/ubuntu/kicad-dev-nightly/+packages thereās no package for opencascade for groovy and focal. Is that intentional?
Output from apt-cache:
$ apt-cache showpkg kicad-nightly
Package: kicad-nightly
Versions:
202103190931+472d0e03fc~119~ubuntu20.10.1 (/var/lib/apt/lists/ppa.launchpad.net_kicad_kicad-dev-nightly_ubuntu_dists_groovy_main_binary-amd64_Packages)
Description Language:
File: /var/lib/apt/lists/ppa.launchpad.net_kicad_kicad-dev-nightly_ubuntu_dists_groovy_main_binary-amd64_Packages
MD5: 72c04ae16902364d0d7d4fda98c87042
Description Language: en
File: /var/lib/apt/lists/ppa.launchpad.net_kicad_kicad-dev-nightly_ubuntu_dists_groovy_main_i18n_Translation-en
Reverse Depends:
kicad-nightly-dbg,kicad-nightly 202103190931+472d0e03fc~119~ubuntu20.10.1
kicad-nightly-templates,kicad-nightly
kicad-nightly-symbols,kicad-nightly
kicad-nightly-packages3d,kicad-nightly
kicad-nightly-libraries,kicad-nightly
kicad-nightly-footprints,kicad-nightly
kicad-nightly-demos,kicad-nightly
Dependencies:
202103190931+472d0e03fc~119~ubuntu20.10.1 - libc6 (2 2.29) libcairo2 (2 1.14.0) libcurl4 (2 7.16.2) libgcc-s1 (2 3.4) libgl1 (0 (null)) libglew2.1 (2 1.12.0) libglib2.0-0 (2 2.35.9) libglu1-mesa (16 (null)) libglu1 (0 (null)) libgtk-3-0 (2 3.9.10) libocct-data-exchange-7.4 (0 (null)) libocct-foundation-7.4 (0 (null)) libocct-modeling-algorithms-7.4 (0 (null)) libocct-modeling-data-7.4 (0 (null)) libocct-ocaf-7.4 (0 (null)) libpixman-1-0 (2 0.15.14) libpython3.8 (2 3.8.2) libstdc++6 (2 9) libwxbase3.0-0v5 (2 3.0.5.1+dfsg) libwxgtk3.0-gtk3-0v5 (2 3.0.5.1+dfsg) zlib1g (2 1:1.1.4) python3-wxgtk4.0 (0 (null)) libngspice-kicad (16 (null)) libngspice0 (0 (null)) xsltproc (0 (null)) kicad-nightly-demos (0 (null)) libocct-modeling-algorithms-7.3 (16 (null)) libocct-modeling-algorithms-7.5 (0 (null)) libocct-modeling-data-7.3 (16 (null)) libocct-modeling-data-7.5 (0 (null)) libocct-data-exchange-7.3 (16 (null)) libocct-data-exchange-7.5 (0 (null)) libocct-visualization-7.3 (16 (null)) libocct-visualization-7.5 (0 (null)) libocct-foundation-7.3 (16 (null)) libocct-foundation-7.5 (0 (null)) libocct-ocaf-7.3 (16 (null)) libocct-ocaf-7.5 (0 (null)) kicad-nightly-locale-bg (0 (null)) kicad-nightly-locale-ca (0 (null)) kicad-nightly-locale-cs (0 (null)) kicad-nightly-locale-de (0 (null)) kicad-nightly-locale-el (0 (null)) kicad-nightly-locale-es (0 (null)) kicad-nightly-locale-fi (0 (null)) kicad-nightly-locale-fr (0 (null)) kicad-nightly-locale-hu (0 (null)) kicad-nightly-locale-id (0 (null)) kicad-nightly-locale-it (0 (null)) kicad-nightly-locale-ja (0 (null)) kicad-nightly-locale-ko (0 (null)) kicad-nightly-locale-lt (0 (null)) kicad-nightly-locale-nl (0 (null)) kicad-nightly-locale-pl (0 (null)) kicad-nightly-locale-pt (0 (null)) kicad-nightly-locale-ru (0 (null)) kicad-nightly-locale-sk (0 (null)) kicad-nightly-locale-sl (0 (null)) kicad-nightly-locale-sv (0 (null)) kicad-nightly-locale-zh (0 (null)) kicad-nightly-libraries (0 (null)) kicad-nightly-doc-en (0 (null)) extra-xdg-menus (0 (null))
Provides:
Reverse Provides:
Thanks,
Christian
FWIW, this does not happen on Hirsute, installs just fine. Seems to be contained to Groovy.
