I’m also having a problem with this.
After an “sudo apt update” the my current output of “sudo apt upgrade” (On my linux Ming box) is:
Reading package lists... Done
Building dependency tree
Reading state information... Done
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libocct-data-exchange-7.5 : Breaks: libocct-data-exchange-7.3 but 7.3.3+dfsg1-1build1 is to be installed
libocct-foundation-7.5 : Breaks: libocct-foundation-7.3 but 7.3.3+dfsg1-1build1 is to be installed
libocct-modeling-algorithms-7.5 : Breaks: libocct-modeling-algorithms-7.3 but 7.3.3+dfsg1-1build1 is to be installed
libocct-modeling-data-7.5 : Breaks: libocct-modeling-data-7.3 but 7.3.3+dfsg1-1build1 is to be installed
libocct-ocaf-7.5 : Breaks: libocct-ocaf-7.3 but 7.3.3+dfsg1-1build1 is to be installed
libocct-visualization-7.5 : Breaks: libocct-visualization-7.3 but 7.3.3+dfsg1-1build1 is to be installed
E: Broken packages
paul@medion:~$
Unfortunately I’m having a lot of trouble on focusing on such problems.
Luckily Mint as an “update manager” that can still update all the other stuff even with these broken packages.
