While attempting to import an non-Kicad schematic generated by Eagle, I received a schematic editor error as follows:
![image](//kicad-info.s3.dualstack.us-west-2.amazonaws.com/original/3X/5/6/56faf9e25f23e788fe492ea8ea606b59ae534b84.png)
The original file came from Adafruit’s github for one of their hardware products. I successfully opened the schematic with Eagle, made a change, saved the file to ensure it was produced by the Eagle version as indicated, below. Upon attempting to “Import/Non-Kicad Schematic…” I received the above error. I tried this sequence with multiple Eagle files from Adafruit with the same result. If need be, I can post the actual Eagle file as it’s in the public domain.
Context
Generating software: Eagle v9.6.2
Kicad software: v8.0.3
Computing environment: iMac M1, MacOS v14.5
Just posting a link would have been plenty.
I cloned:
After that, both the schematic and the PCB imported in KiCad.
I also managed to crash KiCad a few times just after the import of the PCB. I don’t know what’s going on here, but I may put some more time into that.
More general:
I don’t particularly like these PCB’s for an HD44780 based around an I2C I/O expander. You need a lot of I2C traffic to get these things going, while the price difference between an I/O expander and a uC is negligible. With an uC you can also add keyboard multiplexing and and some other typical “front panel” functions, and then control the whole front panel of a project with either I2C or SPI,
Update. I tried a bunch of times but KiCad crashes a lot, and after a bit of fiddling and it does not crash, then the final result is the same error message that you get.
My workflow as sort of:
- Clone the project from github.
- Create a KiCad project.
- Import the schematic (This looks OK).
- Import the PCB (This also looks OK).
- Save files and exit: KiCad is slow, often crashes.
- Restart KiCad, attempt to open the schematic. KiCad responds with:
and then closes the schematic editor.
KiCad version used:
Version: 8.0.3-8.0.3-0~ubuntu20.04.1, release build
wxWidgets 3.2.2
FreeType 2.10.1
HarfBuzz 2.6.4
FontConfig 2.13.1
Platform: Linux Mint 20.3, 64 bit, Little endian, wxGTK, X11, xfce, x11
OpenGL: AMD, AMD RENOIR (DRM 3.42.0, 5.15.0-107-generic, LLVM 12.0.0), 4.6 (Compatibility Profile) Mesa 21.2.6
Date: Jun 4 2024 12:41:44
Boost: 1.71.0
OCC: 7.6.3
Curl: 7.68.0
ngspice: 42
You have a reproducible bug here, please raise an issue on the tracker
It took me some time to create the issue:
And it was fixed 5 days later, and it should be included in KiCad V8.0.4
