KiCad 8 Stimulus File Times
Here a stim that works:
* T      p
* i      1
* m
* e
0us      0s
100us    1s
1.6ms    0s
10.0ms    0s
Now, I change the unit from u to m (2. time line):
* T      p
* i      1
* m
* e
0us      0s
0.1ms    1s
1.6ms    0s
10.0ms    0s
ERROR **
D_SOURCE: source.in file was not read successfully.
Instance: a.xu3.a_1   Message:  Time values in first column have to increase monotonically.
Instance: a.xu3.a_1   Message:  dsource will return only its initial state.
I think 100us = 0.1 ms, isn’t it?
I think, d_source ignored the dot.
No fractional numbers allowed?
1.6ms treat as 1 ms.
Works fore me (Linux and Windows).
Is your input file encoding ANSI or UTF-8? Others may not be recognized by KiCad/ngspice.
that works, But the 1.6 ms is treated as 1 ms.
Dot’s are ignored.
The first example don’t works. Because 100us = 1ms.
My file is UTF-8, LF.
Look at hex editor: it’s simple 7-bit ASCII.
Please post the project file here, zipped, including all necessary files, which does show this behavior.
Have created a new simplified project.
Don’t forget to change the “cd” in IMP.lib.
TestStim.zip (20.5 KB)
I have unpacked your example, changed the cd command and run the transient. This is my result, for 100us as well as for 0.1ms (Windows 10, and SUSE Tumbleweed):
What is your operating system? Do you have a locale setting which uses comma as the decimal separator? If yes, could you switch LC_NUMERIC to “C” for testing?
Use the ‘locale’ command and post the response.
switch to en_US:
LANG=en_US.UTF-8
LANGUAGE=en_US
LC_CTYPE="en_US.UTF-8"
LC_NUMERIC=en_US.UTF-8
LC_TIME=en_US.UTF-8
LC_COLLATE="en_US.UTF-8"
LC_MONETARY=en_US.UTF-8
LC_MESSAGES="en_US.UTF-8"
LC_PAPER=en_US.UTF-8
LC_NAME=en_US.UTF-8
LC_ADDRESS=en_US.UTF-8
LC_TELEPHONE=en_US.UTF-8
LC_MEASUREMENT=en_US.UTF-8
LC_IDENTIFICATION=en_US.UTF-8
LC_ALL=
it works, pulse ends at 1.6ms
Deutsch:
LANG=de_DE.UTF-8
LANGUAGE=de_DE
LC_CTYPE="de_DE.UTF-8"
LC_NUMERIC=de_DE.UTF-8
LC_TIME=de_DE.UTF-8
LC_COLLATE="de_DE.UTF-8"
LC_MONETARY=de_DE.UTF-8
LC_MESSAGES="de_DE.UTF-8"
LC_PAPER=de_DE.UTF-8
LC_NAME=de_DE.UTF-8
LC_ADDRESS=de_DE.UTF-8
LC_TELEPHONE=de_DE.UTF-8
LC_MEASUREMENT=de_DE.UTF-8
LC_IDENTIFICATION=de_DE.UTF-8
LC_ALL=
wrong, pulse ends at 1.0ms
I can’t use ‘,’ aka 1,6ms.
This generates a error in the simulation.
OS/Kicad:
Version: 8.0.1-8.0.1-0~ubuntu20.04.1, release build
    wxWidgets 3.2.1
    FreeType 2.10.1
    HarfBuzz 2.6.4
    FontConfig 2.13.1
Platform: Linux Mint 20.3, 64 bit, Little endian, wxGTK, X11, xfce, x11
    Date: Mar 14 2024 15:11:44
    Boost: 1.71.0
    OCC: 7.6.3
    Curl: 7.68.0
    ngspice: 42
