KiCAD 7: Can't set my preferred language
with KiCAD 7 I am unable so set my preferred language. I installed the kicad-doc-* package, but if i try to set my language it says it is not installed. Am i missing something or is this a bug?
Version: 7.0.0-da2b9df05c~165~ubuntu22.04.1, release build
	wxWidgets 3.2.1
	FreeType 2.11.1
	HarfBuzz 6.0.0
	FontConfig 2.13.1
	libcurl/7.81.0 OpenSSL/3.0.2 zlib/1.2.11 brotli/1.0.9 zstd/1.4.8 libidn2/2.3.2 libpsl/0.21.0 (+libidn2/2.3.2) libssh/0.9.6/openssl/zlib nghttp2/1.43.0 librtmp/2.3 OpenLDAP/2.5.13
Platform: Ubuntu 22.04.2 LTS, 64 bit, Little endian, wxGTK, gnome, wayland
	Date: Feb 22 2023 09:43:42
	Boost: 1.74.0
	OCC: 7.5.2
	Curl: 7.87.0
	ngspice: 38
	Compiler: GCC 11.3.0 with C++ ABI 1016
	KICAD_SPICE=ON
for the same system I can confirm this here for the following installation method
sudo add-apt-repository --yes ppa:kicad/kicad-7.0-releases
sudo apt update
sudo apt install --install-recommends kicad
there is no directory /usr/share/kicad/internat/
I’m not on Ubuntu but looking into the PPA I see the kicad-doc-<lang> packages are present:
https://ppa.launchpadcontent.net/kicad/kicad-7.0-releases/ubuntu/pool/main/k/kicad-doc/
However, looking at my distro, this is the description of the kicad-doc-de package: German documentation and tutorials for KiCad
Whereas there is a kicad-lang-de package whose description is: German translations for KiCad
So maybe it’s the kicad-lang-<lang> package you should be installing.
There is no kicad-lang-* package available for me
Yeah, I don’t see them in the PPA. Maybe raise a ticket for the Ubuntu packages maintainer to build them?
Just found the “problem”
The same problem in Linux Mint 21.1
If someone is in urgent need of the language, you can fix it with this command
sudo ln -s /usr/lib/kicad/share/kicad/internat/ /usr/share/kicad/internat
Can you try Ubuntu 7.0 testing builds and see if it fixes the problem?
Now it works OK in Linux Mint 21.1. Thanks.
Ubuntu automatic software updater also solved the problem now automatically
Current stable solved the problem
Version: 7.0.0-da2b9df05c~171~ubuntu22.04.1, release build
