I’m one of those people that can’t forget old tricks easily.
Thank you for pointing this out. I’ll update the article.
With your permission, I’d like to acknowledge your contribution (you have made a lot of excellent comments in this thread). Can I link to your profile, or somewhere else?
Feel free to do that. I don’t have any good website or anything else, so the profile is OK.
One of the most prominent uses will probably be local area rules, for example narrow track width/clearance near a BGA. In the Syntax Help in Board Setup -> Custom Rules x.insideCourtyard('refdes') is used, but it can be a rule area and x.insideArea('rule_area_name').
Nah, I think the most important are here, except the Altium import. You have to start eeschema and pcbnew in standalone mode to use it because it doesn’t import projects, only files.
In pcbnew items can be grouped together, context menu -> Group. Then they can be moved only as a group.
Locking different kinds of items works now. In v5 even track locking didn’t work properly, and graphics couldn’t be locked at all. (Locking means locking the placement and existence.)
You can see some board statistics from Tools.
The very long thread Post-v5 new features and development news is still worth reading through (if you haven’t done so already), although the information about each feature may be outdated (announced when the initial version of the feature was introduced). It has links to further discussions. If you can take time to go through it, it can work as a checklist. All important features are at least mentioned there and also many small ones.
The new settings system is something I forgot. It’s a major change under the hood. Important for those who are curious enough to try the development version along with the stable one: 5.99 has its own configuration folder and doesn’t interfere with v5. On Windows the nightly installer was recently changed so that 5.99 installation is completely separated from v5 installation. When post-v5 development was started it required hacking. Now it should be safe to recommend trying v5.99 without hassle as long as the projects opened with it are copies, not originals.
Here’s still one list, fulfilled feature requests for v6:
The infobar! People don’t like messages dialogs which interrupt the workflow, so some of them have been replaced by an infobar message and some situations which would have been cryptic without any information are now noticed. See an example in Library is not writeable (custom) SOLVED.
Or choose a read-only layer color theme for pcbnew and try to edit layer colors:
I believe this article can be an useful summary. I’ve just started reading it and I’ve seen you mention a few times:
KiCad 6.0 is expected to arrive in the second quarter of 2021
Don’t know if it’s a typo or too much optimism, hehe!
My impression after reading Yet another release date 6.x question is that it could be closer to the end of the year. Anyway, there’s no guarantee and it will be ready when it’s ready.
At the moment I would guess the third quarter, seeing the pace of development. Again: please, everyone, test and report the issues. It will make it quicker.
KiCad developers have been very busy and delivered an impressive number of improvements since last major release, including some internal reworking, but all that new code will take a while to polish.
An effect I recently noticed is that when a new release seems imminent, users take the opportunity to try it out and give feedback, so the rate of new issues goes up several notches. Most of these are as-designed, duplicate, wish list, but a significant few reveal bugs or UI improvements.
Looking at the burn-down charts (which I don’t think are public), they are headed in the right direction but probably not as quickly some hope (ie. situation normal :)). There is also the pandemic which is messing up a lot of plans. I think “sometime this year” is still in the ball park.
X means any item which is tested against the rule. It’s just a random name. In one rule all X (or A or foobar or item…) are the same. If I want to set minimum clearance between any via and any track (of different nets) I would write
(condition "A.Type=='via' && B.Type == 'track'")
Here we have two different items, a via and a track. Inside one condition every A is the same, so
(condition "A.Type=='via' || A.Type == 'track'")
would mean that the item is either a via or a track.
The UI has Syntax Help link in the Board Settings -> Custom Rules page. You can also try to learn something from Need some guinea pigs for a rule-based DRC <<PROTOTYPE>>. Unfortuntately older posts aren’t up to date, it shows the changing situation with syntax and features.
Hello!
Thanks for the review, it’s very useful for people in a hurry I think. That said, I didn’t read in detail…
I noticed something here:
“In the right screenshot, I have selected the “All Copper Layers” preset.”
On my screen, the “all copper corners” displays on the left.
By the way, I would like to try it. I have setup a virtual PC on my linux box.
Now I would like to download Kicad 5.99. The link you provide points to github.
Is there an installer package somewhere? I don’t want to mess with compilation.
I checked the nightly builds, but it’s labeled kicad-r20448.0a1a5ea669-i686.exe
so the version is unclear.
Thank you, I have fixed right --> left (always confuse those two).
To install KiCad nightly build on Ubuntu, check out the instructions here.
No need to download anything manually. Use the command line to set the correct nightly repository, and use apt to install it. Also update every couple of days (instructions in the article).
(EDIT: maybe it was some cache issue, now the article has changed.)
I tried to find the changed bits but don’t find any with quick reading. Are you sure the web page has been updated?
BTW, you have an error WRT backannotation:
For example, if you add a footprint that is not represented in the schematic, you can simply use this function to import the symbol for the footprint to the Eeschema editor.
You can’t add a symbol for a footprint in Pcbnew. All footprints added in Pcbnew will be only in the layout.
What backannotation also can’t do is reassign nets or change connections. It can only rename existing nets. (That’s not a problem in the article, but I tell this just for clarity. One can wish that all changes could be made in the layout and propagated to the schematic, but that would be much more difficult and would require basically duplicating some of the functionality of the layout editor in the schematic editor.)
