I’ve created a simple circuit with a Fairchild J112 JFET, self-biased using a resistor (R3) between the source pin and ground. Here is the schematic: JFET-ClassA.sch (3.5 KB)
When I run a simulation with a voltage sweep at the input, the voltage across R3 is essentially zero the whole time, as is current. It should definitely be non-zero as there is current running through R2 and it should be the same as the current through R3.
But, looking at the netlist, I can see why. JFET-ClassA.cir (202 Bytes)
On line 2, it’s got the pins for gate and source swapped, at least in relation to the Spice NJF reference I found here: http://bwrcs.eecs.berkeley.edu/Classes/IcBook/SPICE/UserGuide/elements_fr.html
The expectation of the NJF model is drain, gate, source. The J112 is drain, source, gate. I’ve searched the forum and the web, but I have yet to find a solution for getting the proper pin order.
Any help is appreciated.
