Issues with time dependent elements in NGSpice depending on the OS or version
Hi all!
I am having the following issue when utilizing the variable TIME with NGSPICE:
When I run the simulation using my old computer (Ubuntu 16 and NGSpice v 32) it works perfectly. Instead, when I ran the same code using Windows 11 and NGSpice v 43, I got nonsense.
As an example, the code I post below utilizes two transmission lines coupled to a time-dependent capacitor. This simple code is enough to see the type of analysis I am trying to make.
See in the link a plot comparing the output of the two respective runs:
https://ibb.co/GR674v0
I hope you can help me understand better the origin of the problem, and hopefully, how to fix it.
Many thanks!
Lucas
.title TD Dimer
* Parameters...
.param Ck0 = 96.08436682642376pF
.param Ck1 = 86.47593014378138pF
.param wm = 251.32741228718345kHz
.param freq=215kHz
.param T=1/freq
.param step_time = T/500.
.param end_time = T*100
* Specify some initial node voltages
.ic v(v1)=0 v(v2)=0 		$ ic: initial conditions
*    TIME MODULATED CAPACITOR
*    ASCII SCHEME
*      v1    v2
*====o----||----o==== Transmission Line
*         k(t)
* leads (50 Ohm with sources)
*Transmission line 1
Vs1 0 vs1 SIN(0V 1V 215kHz 0s 0Hz)
RZ0_1 vs1 v1 50Ohm
*Transmission line 2
Vs2 vs2 0 SIN(0V 0V 215kHz 0s 0Hz)
RZ0_2 vs2 v2 50Ohm
* Time modulated capacitor
Ck v1 v2 {Ck0 + Ck1 * cos(wm * TIME)}
* Transient analysis specs and control
.TRAN {step_time} {end_time} UIC
.control
    run                              $ run the file
    linearize                        $ resample all points on steps
    plot v(v2)                     $ plot the oscillator voltage vector
    set wr_singlescale                      $ only print out one time scale
    wrdata nodes_v1_v2.dat v(v1),v(v2)            $ write
.endc
.END
Please edit your text and mark all code sections as “preformatted text”. Otherwise it is unreadable or unusable.
There has been a bug in ngspice (fixed in ngspice-44.2), in that ngspice assumes this to be a charge equation.
Please use
Ck v1 v2 C = {Ck0 + Ck1 * cos(wm * TIME)}
Hi Holger!
When I edited the text, you replied before I could thank you!
So, thank you.
Your suggestion worked! Thank you so much!
Best regards,
Lucas
