Hi KiCaders,
Is it possible to force zone to clearance to value lower than its Netclass clearance?
I’m doing some RF and I use Coplanar waveguides, which require me to set certain clearance to ground plane.
However there are structures I need to approach with clearances tighter than calculated RF-to-GND distance (compact packages), using copper Zones (for smooth track width changes).
But if I set a general RF clearance which is needed for a coplanar waveguide, my RF zones are not filled. I have tried to set their clearance to lower values, but they stop on the netclass value.
Any workaround for this?
write a custom rule.
Maybe this project could help:
create_lines.zip (25.8 KB)
move to KIcad 8RC2, rules are much more sophisticated. No problem with specifying rules for CPW. I have done it. Just set a zone clearance rule for the netclass … easy Check the new doco for custom design rules :
(rule "zone clearance myCPW "
(layer outer)
(condition " A.NetClass == 'myCPW' && B.Type=='zone'")
(constraint clearance (min 0.15mm) (opt 0.15mm) (max 2mm)))
you might need to add a rule area to that condition if you dont want it tight around component pads etc
or add a rule after it (higher priority) to apply to pads.
like
(rule "cpw tracks"
(layer outer)
(condition " A.NetClass == 'HV' && B.Type=='zone' && A.Type=='Track'")
(constraint clearance (min 0.15mm)))
(rule "cpwnetclass pads"
(layer outer)
(condition " A.NetClass == 'HV' && B.Type=='zone' && A.Type=='Pad'")
(constraint clearance (min 0.5mm)))
Thanks, I’ve got my homework now to do
So the easiest solution to me was to use a specific name for the “tight RF” Zones, and then create a name-based custom rule to override the clearance for the “TIGHTRF” named zones to my desired smaller value - exactly as in mf_ibeew example. Thank you @mf_ibfeew @glenenglish for pointing me to the right direction.
I have also noticed that I can re-use my Zone name for multiple indepenedent zones, actually using these Zone names as a sub-Netclass for my custom rule.
