For whatever it is worth, .rar is not a cross platform compression system so many people will not be able to open the file as provided. Most OS’s other than Windows default to .zip rather than .rar for compression. There are certainly workarounds (on Mac there is a common utility called The Unarchiver) but I figured I’d let you know.
Anyways, I was able to open your schematic file without any issues and re-attach the IR1201 models without any issue. I noticed you’ve excluded the IR1201’s from simulation, presumably to keep it from crashing? I unchecked that setting on the top IR1201, no crash yet. I opened the simulator window, transient model with default settings, and set compatability to PSPICE. Running the simulation does result in an error message.
Note: Compatibility modes selected: ps a
Circuit: KiCad schematic
PWL-ERROR: prepare_PTF_PWL, not a constant
type = 3
Error: PWL(expr, points...) only *literal* points are supported
type = 3
type = 3
type = 3
type = 3
type = 3
type = 4
type = 4
Error on line 0 or its substitute:
b.xu1.x_gd_template.x_hin_vcc_d.btable_new_8 xu1.x_gd_template.x_hin_vcc_d.table_new_8 0 v=pwl(v(probe_int_hin_xu1_5,probe_int_+v_xu1_6) , 0,0 , 3.000000000000000e-01 *1.01,0 , 3.000000000000000e-01 *1.02, 1.000000000000000e-03 , 10* 3.000000000000000e-01 , 100* 1.000000000000000e-03 )
parameter value out of range or the wrong type
Error: circuit not parsed.
Just for fun, I switched compatibility mode to PSICE and LTSPICE, hit OK, and immediately got a crash. This is reproducible with just the LTSPICE compatibility mode as well.
Translated Report (Full Report Below)
Process: kicad [10608]
Path: /Applications/KiCad/KiCad.app/Contents/MacOS/kicad
Identifier: org.kicad.kicad
Version: 7.0.5-0 (7.0.5-0)
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2023-07-02 11:37:06.6325 -0700
OS Version: macOS 13.4.1 (22F82)
Report Version: 12
Anonymous UUID: 0B770BD3-37DB-5FD8-F5F2-D277A651BA40
Sleep/Wake UUID: CA36FC49-74D3-4307-A031-B5BD5D33B81C
Time Awake Since Boot: 84000 seconds
Time Since Wake: 942 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000010
Exception Codes: 0x0000000000000001, 0x0000000000000010
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [10608]
VM Region Info: 0x10 is not in any region. Bytes before following region: 105556203274224
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
MALLOC_NANO (reserved) 6000b8000000-6000c0000000 [128.0M] rw-/rwx SM=NUL ...(unallocated)
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libngspice.0.dylib 0x28504e9b4 modprobenames + 24
1 libngspice.0.dylib 0x285031480 inp_dodeck + 884
2 libngspice.0.dylib 0x28502f368 inp_spsource + 4560
3 libngspice.0.dylib 0x28502e190 inp_source_recent + 56
4 libngspice.0.dylib 0x285064fc0 com_rset + 96
5 libngspice.0.dylib 0x285016d5c docommand + 1060
6 libngspice.0.dylib 0x285016528 doblock + 2328
7 libngspice.0.dylib 0x285015960 cp_evloop + 3764
8 libngspice.0.dylib 0x285004368 runc + 464
9 libngspice.0.dylib 0x28500416c ngSpice_Command + 180
10 _eeschema.kiface 0x11aa1f978 NGSPICE::Init(SPICE_SIMULATOR_SETTINGS const*) + 132
11 _eeschema.kiface 0x11aa2c1d8 SIM_PLOT_FRAME::onSettings(wxCommandEvent&) + 1716
12 libwx_osx_cocoau-3.2.0.2.1.dylib 0x1054b2278 wxEvtHandler::SearchDynamicEventTable(wxEvent&) + 360
13 libwx_osx_cocoau-3.2.0.2.1.dylib 0x1054b1f1c wxEvtHandler::ProcessEventLocally(wxEvent&) + 88
14 libwx_osx_cocoau-3.2.0.2.1.dylib 0x1054b1d44 wxEvtHandler::ProcessEvent(wxEvent&) + 56
15 _eeschema.kiface 0x11ac17eb0 EDA_BASE_FRAME::ProcessEvent(wxEvent&) + 96
16 libwx_osx_cocoau-3.2.0.2.1.dylib 0x1056c1fe4 wxWindowBase::TryAfter(wxEvent&) + 252
17 libwx_osx_cocoau-3.2.0.2.1.dylib 0x1054b2538 wxEvtHandler::SafelyProcessEvent(wxEvent&) + 24
18 libwx_osx_cocoau-3.2.0.2.1.dylib 0x1056ab5cc wxToolBarBase::OnLeftClick(int, bool) + 124
19 AppKit 0x1a7b218a8 -[NSApplication(NSResponder) sendAction:to:from:] + 440
20 AppKit 0x1a7b216c0 -[NSControl sendAction:to:] + 72
21 AppKit 0x1a7b21604 __26-[NSCell _sendActionFrom:]_block_invoke + 100
22 AppKit 0x1a7b2152c -[NSCell _sendActionFrom:] + 204
23 AppKit 0x1a7b21450 -[NSButtonCell _sendActionFrom:] + 88
24 AppKit 0x1a7b1ea54 NSControlTrackMouse + 1480
25 AppKit 0x1a7b1e460 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 144
26 AppKit 0x1a7b1e318 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 488
27 AppKit 0x1a7b1d7e4 -[NSControl mouseDown:] + 448
28 AppKit 0x1a7b1c2cc -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 3476
29 AppKit 0x1a7aa6f08 -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 364
30 AppKit 0x1a7aa6bc8 -[NSWindow(NSEventRouting) sendEvent:] + 284
31 libwx_osx_cocoau-3.2.0.2.1.dylib 0x105599678 -[wxNSWindow sendEvent:] + 124
32 AppKit 0x1a7aa5f0c -[NSApplication(NSEvent) sendEvent:] + 1556
33 libwx_osx_cocoau-3.2.0.2.1.dylib 0x1054c1138 -[wxNSApplication sendEvent:] + 100
34 AppKit 0x1a7cf5fc4 -[NSApplication _handleEvent:] + 60
35 AppKit 0x1a796d368 -[NSApplication run] + 500
36 libwx_osx_cocoau-3.2.0.2.1.dylib 0x10558ff54 wxGUIEventLoop::OSXDoRun() + 196
37 libwx_osx_cocoau-3.2.0.2.1.dylib 0x1054868c4 wxCFEventLoop::DoRun() + 40
38 libwx_osx_cocoau-3.2.0.2.1.dylib 0x1053dd630 wxEventLoopBase::Run() + 192
39 libwx_osx_cocoau-3.2.0.2.1.dylib 0x1053ae0a0 wxAppConsoleBase::MainLoop() + 208
40 libwx_osx_cocoau-3.2.0.2.1.dylib 0x10552d888 wxApp::OnRun() + 36
41 kicad 0x1029fc2c4 APP_KICAD::OnRun() + 28
42 libwx_osx_cocoau-3.2.0.2.1.dylib 0x105410154 wxEntry(int&, wchar_t**) + 88
43 kicad 0x1029fa7b8 main + 52
44 dyld 0x1a4323f28 start + 2236
This is reproducible with a minimum case of just the Simulation_SPICE:OPAMP symbol in an otherwise empty schematic.
temp.kicad_pro (10.8 KB)
temp.kicad_sch (4.0 KB)
IR2101.lib (21.6 KB)
temp.wbk (90 Bytes)
All of this to say there are two or three issues here (from my point of view):
The IR1201 model is not fully compatible with ngspice (the underlying spice library) even with the PSPICE compatibility mode. Something about it is Really broken when you throw LTSPICE compatibility mode into the mix, even though they should be able to operate together (“LTPSA should be the standard” from PSPICE simulation fails permanently (#13589) · Issues · KiCad / KiCad Source Code / kicad · GitLab ).
Then there’s the KiCad level issue of crashing when ngspice does, which may be covered by the pair of these issues: Spice simulator cause Kicad to crash if netlist includes a spice library with syntax errors (#14568) · Issues · KiCad / KiCad Source Code / kicad · GitLab and Crashing simulation (ngspice) should not crash kicad / eeschema (#9756) · Issues · KiCad / KiCad Source Code / kicad · GitLab.
