Input file not compatible at simulation startup
The ngspice simulator found one or more compatibility errors when I opened it from the schematic in my biasing circuit project (.zip file containing project and error message screenshot) attached), using KiCad v.8.0.6. Before attempting this overall simulation, I first tested each component requiring a non-built in Spice model in an individual test circuit to verify that each component’s simulation run worked properly.
80 GHz module biasing_supply_interlock validation.zip (3.1 MB)
Could someone please advise me on what is wrong?
Thank you.
The simulator does tell you:
double definition of a subcircuit, probably not critical when both are the same, one of the two is ignored.
rt1: there is a device rt1 (temp dependent resistor) which does not have a ngspice model.
J2: a device without ngspice model
There are at least others:J1, J3, J4 which are connectors. If you don’t want to simulate them, exclude them from simulation. Otherwise you have to provide a spice model.
If you don’t need U1, exclude it. If you need only part of the inverters, tie the other inputs to GND. Never leave CMOS inputs open.
Implemented those corrections, thank you.
