Ignoring "Board edge clearance violation" KiCad v7.0.6?
Hi, help/advice needed. Can I ignore this error?
I have a specific PCB that is designed with Edge cuts layer cutting off an arc of the circular through-hole pad (that has All cooper layers connected, in this case F.Cu and B.Cu)
I am pretty amazed by KiCad as in the 3D view of the PCB it looks just like I want it to look. Pad is covering the inner edge of the hole making contact possible on F.Cu and B.Cu. It is cut off where it needs to be cut off. But… the error “Board edge clearance violation” is raised. That is why I wonder is it safe to create Gerber files and send it as such to the manufacturer.
Has anyone had somewhat similar PCB issue and produced it regardless of the error and did it turn out OK?
I have checked this topic:
..it helped me to understand what is going on and what KiCad is complaining on. But still, my requirement is for the Edge cuts layer to cut off that copper from that pad. It is a bit of an unusual requirement, but there it is :blush:
Thanks!
If you want this, then ignore the kicad warning.
But be aware that the resulting boards might contain flaws. Milling through copper is not recommended by the pcb manufacturers. Some pcb manufacturers also simply reject such boards. Every pcb manufacturer has it’s own design constraints, and you are probably violating these with your design.
So you should ask your pcb manufacturer if your solution is good enough.
In general your question looks like you want to implement something like a custom sideplating on some places of the board edge. This feature is currently not natively supported by kicad. Depending on the pcb manufacturer there are different recommendations to achieve this. So that is also a question for the manufacturer.
last note: looking at the milling cutout it seems it is very thin. Ask for the minimal available diameter for the milling bit - you should not draw cutouts with smaller dimensions.
yes, like you say, it is dependent on the manufacturing process, there is probably a risk of pealing the copper (ENIG) while milling. If someone had a good experience with manufacturing something similar, I would be glad to hear it (if not permitted to post about it, you can DM me).
yep, thanks. I hope I get it produced right. This is the first time that I have such untypical design requirements, so I am trying to get as much info as possible.
it’s a valuable precautious observation from you as I did not specify the dimensions. tnx & respect.. the inner diameter of the pad is 2.54 mm and the passage is not less than 1.5 mm. I see drill size range stated by the manufactures is covering it.
But, I am not sure how the passage between the two circle holes is drilled/milled, not an expert on this processes.. and the PCB is very thin, and flexible, actually a PET, so maybe they laser cut it or machine cut, i don’t know.. will also have to check. I hope a good manufacturer will take care of all of these questions
Drilling a hole and milling a slot use different tools. The problem with milling into copper is that it ‘sticks’ to the bit and alters the chip load. Small milling bits running at 50k rpm can break quite easily if the flutes get gummed up. I would speak to your manufacturer first.
Tnx! That’s a good insight, I guess I will have to take special care to resolve that with the manufacturer.
Please advise if there are any other issues that I would need to communicate to the manufacturer or if you know of any standard practices how such features can be specified to the manufacturer in KiCad. It is probably something that should be pointed in the comments and resolved through email conversation with the tech support from the manufacturer
The NPTH hole also looks way to close to the THT pad next to it. It’s likely to violate manufacturing rules.
Where did you get this switch footprint from?
Here is a feedback if someone else will be having a similar question. PCB has arrived and visually looks ok.
sry @davidsrsb didn’t see your post. Yes, the NPTH hole cuts off a small part of the pad. It could cause problems, likewise is the cutting of that arc of the MX pin pad while milling towards the other MX pin pad.
I designed it as a custom footprint by following standard Cherry MX key switch design dimensions available at CHERRY MX Developer Information | Individual MX keyboard - Cherry.
if you are in a keyboard DIY space you might wonder why my MX pin pad has a bigger pad radius then in the standard MX. It is due to leaving space that is needed to host hot swappable sockets for the MX pins. So I kind of need it that big… I would like to have hot swaps in the keyboard so anyone can replace their key switches as by their preference. You can check the project at https://keybird.io . Page is in development – for sure KiCad community be in the acknowledgments! Thanks folks!
