Muz
October 17, 2024, 3:07pm
1
I have a file in a subfolder of the project location and I wanna create a link from a text field within Kicad.
I tried file://Folder/File.txt, the textfile is then clickable but it does not open the file. I didn’t find any documetation regarding this topic.
How do I create hyperlinks to files relative to the project folder?
Version: 8.0.5-1.fc40, release build
wxWidgets 3.2.4
FreeType 2.13.2
HarfBuzz 8.5.0
FontConfig 2.15.0
libcurl/8.6.0 OpenSSL/3.2.2 zlib/1.3.1.zlib-ng libidn2/2.3.7 nghttp2/1.59.0
Platform: Fedora Linux 40 (Workstation Edition), 64 bit, Little endian, wxGTK, X11, gnome, wayland
OpenGL: Mesa, NV126, 4.3 (Compatibility Profile) Mesa 24.1.7
Date: Sep 6 2024 00:00:00
wxWidgets: 3.2.4 (wchar_t,wx containers) GTK+ 3.24
Boost: 1.83.0
OCC: 7.6.3
Curl: 8.6.0
ngspice: 43
Compiler: GCC 14.2.1 with C++ ABI 1019
How about file://${KIPRJMOD}/File.txt?
Muz
October 17, 2024, 3:59pm
3
Perhabs does also not work
In the past I have experimented a bit with abusing the datasheet link in a schematic to link to other things such as JPG’s, local PDF files and even other KiCad projects, and this seemed to work quite well.
When you enter a text string into a text field, it is just text. If you want to add a link, then you have this as an option at the bottom of the text field.
After some more experimenting, there do seem to be problems here.
I added a generic Q_NPN_BCE transistor (without datasheet link) to a project, and added a link to datasheet relative to the project, and that works:
But I can’t get this link working with the link field in a text box:
I get the error:
When I replace the link with an absolute path it does work:
I am not sure whether I’m using the syntax wrong, or if it’s a bug. Hopefully someone else can elaborate here.
Muz
October 17, 2024, 5:43pm
6
Thanks for testing. I did it also with this link option. But I don’t get the error message you get.
An url to a website will be opened in the browser, but not a file path
There has been some previous discussion of this. For the datasheet field, the file:// scheme should work, but for other fields, the results may vary.
I love the way the datasheet field works. Select the schematic symbol, press ‘D’, and the PDF data sheet pops up. I use this constantly through the project lifecycle.
I wish there was a URL field which worked similarly. And wish the Enhanced PDF data sheet would work with my datasheet value. Let me explain why.
On all my projects, I download the PDF datasheet because this contains the design information used in my design. I typically point URL’s to the manufacturer’s site, so I can determ…
Muz
December 17, 2024, 8:57am
8
I tried it with the newest version under windows and there it works.
file://C:\\<absolute path>\issues_R3.txt
When clicking on the textlabel it opens the texteditor with the file.
Application: KiCad Schematic Editor x64 on x64
Version: 8.99.0-3407-g6a48e2c35a, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.0.1
FontConfig 2.15.0
libcurl/8.10.1-DEV Schannel zlib/1.3.1
Platform: Windows 11 (build 22621), 64-bit edition, 64 bit, Little endian, wxMSW
OpenGL: Intel, Intel(R) Iris(R) Xe Graphics, 4.6.0 - Build 31.0.101.3889
Date: Dec 16 2024 07:06:14
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.10.1-DEV
ngspice: 43
Compiler: Visual C++ 1939 without C++ ABI
KICAD_IPC_API=ON
Locale:
Lang: en_US
Enc: UTF-8
Num: 1,234.5
system
Closed
March 17, 2025, 8:57am
9
