Huge problem in R10240 on Windows
Hi folks!
I work with nightly builds. R10225 was ok. Latest from today (R10240) have a huge problem: open pcb become error “OpenGL 2.1 or higher required!”, 3-D viewer looks very strange and any trying to render willcrash KiCAD complete…
My System:
i7 7700
Asus Z270 TUF Mark2 Board
32G RAM
GTX1070 (MSI Armor)
Any idea?
Best regards,
Sebastian
e class='quote' data-post="1" data-topic="9452">
As this is a user forum, the users here can only try to offer a workaround for your problem not a fix. This means there might be a reason to post here but make it clear that you ask for help fixing your problem via a workaround. Bug in the software To help the kicad development effort it is suggested to post your bug description over at the bugtracker. A detailed explanation on how this is done can be found in the report a bug section of the KiCad website. Another detailed description about h…
Thanks a lot, I wrote a report right now..:wink:
Please give a link to the report, too.
Did you try again with the older version?
Open GL 2.1 is ancient. Any modern PC apparently not have at least 2.1 has a broken driver.
There is a major Windows 10 update rolling out right now which will probably break things.
Often, after a Win 10 update, it has necessary to re-install graphic drivers… they are in place, but not working correctly…
The GPU driver is not working after an update Windows 10, or the video card is not detected.
Win 10 updates are a very annoying ‘bug’
