heres the error;-
No compatibility mode selected!
Circuit: * c:\users\abhishek\esim-workspace\com_subc_sim\com_subc_sim.cir
Warning: Model issue on line 1 :
.model cmosp pmos (level=8 version=3.2 tnom=27 tox=4.1e-9 xj=1e-7 nch=4. …
unrecognized parameter (+) - ignored
Doing analysis at TEMP = 27.000000 and TNOM = 27.000000
Checking parameters for BSIM 3.2 model cmosn
Warning: Pd = 0 is less than W.
Warning: Ps = 0 is less than W.
Checking parameters for BSIM 3.2 model cmosp
Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Note: Starting true gmin stepping
Trying gmin = 1.0000E-03 Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Warning: Further gmin increment
Trying gmin = 5.6234E-03 Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Trying gmin = 8.6596E-03 Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Trying gmin = 9.6466E-03 Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Trying gmin = 9.9105E-03 Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Trying gmin = 9.9775E-03 Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Trying gmin = 9.9944E-03 Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Trying gmin = 9.9986E-03 Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Trying gmin = 9.9996E-03 Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Warning: Last gmin step failed
Warning: True gmin stepping failed
Note: Starting dynamic gmin stepping
Trying gmin = 1.0000E-03 Note: One successful gmin step
Trying gmin = 1.0000E-04 Note: One successful gmin step
Trying gmin = 1.0000E-05 Note: One successful gmin step
Trying gmin = 1.0000E-06 Note: One successful gmin step
Trying gmin = 1.0000E-07 Note: One successful gmin step
Trying gmin = 1.0000E-08 Note: One successful gmin step
Trying gmin = 1.0000E-09 Note: One successful gmin step
Trying gmin = 1.0000E-10 Note: One successful gmin step
Trying gmin = 1.0000E-11 Note: One successful gmin step
Trying gmin = 1.0000E-12 Note: One successful gmin step
Warning: Dynamic gmin stepping failed
Note: Starting source stepping
Supplies reduced to 0.0000% Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Trying gmin = 1.0000E-02 Note: One successful gmin step
Note: One successful source step
Supplies reduced to 0.1000% Warning: singular matrix: check nodes net-m9-pad2 and net-m9-pad2
Warning: source stepping failed
Transient solution failed -
Last Node Voltages
Node Last Voltage Previous Iter
net-m3-pad2 3.80365e-50 -6.28714e-61
net-m1-pad2 0 0
net-m3-pad1 -2.32851e-50 0
net-m1-pad1 2.03833e-49 0
net-m9-pad2 0 0
net-m10-pad1 2.03638e-49 0
net-m2-pad1 6.11556e-49 0
net-m11-pad1 6.11803e-49 0
net-m1-pad3 -9.35759e-49 -3.77522e-60
net-m13-pad1 -4.96913e-50 -1.58319e-61
net-m12-pad1 3.59789e-49 0
No. of Data Rows : 0
doAnalyses: iteration limit reached
run simulation(s) aborted
Error(parse.c–checkvalid): net-m1-pad1: zero length vector.
Error(parse.c–checkvalid): alli: zero length vector.
ngspice 1 →
netlist file Link:-
https://drive.google.com/drive/folders/1CJoI_zLkiwCL-xpglQ7Wvnu-zocwHDAF?usp=share_link
