Recently picked KiCad back up from using another CAD package (Proteus PCB) for years, so apologies if this is a dumb question.
During schematic editing, when I select a wire without dragging it’s most likely because I want to delete it. If I want to delete it it’s quite likely that I want to delete either the whole wire, or at least the entire section of the wire up to the closest pin or junction (conceptually I want to delete the connection).
What I probably don’t want to do is delete just the segment of the wire between two corners, although I appreciate the ability to do so.
I found this post which suggests pressing U or alt+4, and neither of these seem to work for me. Am I missing something? Is it broken in version 8?
Also if there’s a way to make this the default selection behavior that would be appreciated - I know making features based on what other CAD packages do is potentially dubious, especially when I’ve only been using KiCad 8 for a few weeks, but as I said earlier, conceptually I’m thinking about connections, not wire segments, so the fact that removing a connection takes many button presses instead of two (click, delete) is a bit of a PITA.
