Sometimes when I click on an Error arrow, it shows me the Error details and some times it just tells me that the thing I clicked on is an Error arrow. How do I make it do the first thing and not the second.
Your category is layout so I assume you are discussing DRC and not ERC?
Please go to help>about> and copy>paste your version information.
Yes, DRC:
Version: 9.99.0-224-gc0e4c6a865, release build
wxWidgets 3.2.6
FreeType 2.13.3
HarfBuzz 10.2.0
FontConfig 2.15.0
libcurl/8.11.1-DEV Schannel zlib/1.3.1
OpenGL: Intel, Intel(R) UHD Graphics, 4.6.0 - Build 31.0.101.5186
Date: Mar 1 2025 06:23:38
Boost: 1.86.0
OCC: 7.8.1
Curl: 8.11.1-DEV
ngspice: 44
KICAD_IPC_API=ON
Locale:
Lang: en_US
Enc: UTF-8
Num: 1,234.5
Kicad 9.99 is the unstable development program that is altered on a daily basis. Faults and problems come and go on regular basis.
The best solution is to wait a few days, download the latest version, and if the problem persists, file a bug report. Any Kicad X.99 should not be used for serious design work.
Take not of this warning: https://www.kicad.org/help/nightlies-and-rcs/
And to add to what jmk said . . . any files you save in V10 (9.99 nightlies) usually won’t be able to be opened in the currently released version v9.0.0
OK, anyway, the problem is not related to version. Kicad 8 does the same thing for me. Sometime it just tell me what I clicked on is an arrow and sometimes it take me to the specific errors in the list of errors.
Can you upload a copy of your Project, I can’t replicate that behaviour on V8.0.8 ?
Sorry, its proprietary. But I can post a screenshot.
Maybe the issue is primarily with this old user of Kicad. I mean when I click on an error arrow, I’d gotten used to it going to the DRC list and showing me the error details there , but it tells me a little of what I need to know this way also. Maybe its supposed to work that way.
Either you are holding the mouse button too long and doing a “Long” click . . . or; there are two markers at the same position so KiCad doesn’t know which one you want info on.
Just click the one you want the info about and it should be highlighted in the Design Rules Checker window.
Or you turn it around: Do a long click explicitly. This gives the context menu which let you select the violation itself. And if the DRC window is open, it also scrolls to the corresponding DRC violation.
not to be rude but why do error arrows still look like they were designed for the Simpsons? may the developers forgot to update error graphics?
The starting quote for anyone about to say something rude.
Would you rather the volunteer Developers spend time on pretty-fying the arrows or fixing bugs ?
I can recognise the arrow as an arrow, it’s therefore, IMO, fit for purpose.
isn’t look also included in software and can be a “bug”?
I fail to see how an arrow which looks like an arrow is a bug.
Call that a…?
What is this obsolete rubbish? KiCad is Modern Software For Modern Users. The current state of the art in pointy war things is in hypersonic glide vehicles. So obviously, the DRC markers should look like this (the blur should be adjustable based on the graphics framerate, but at Mach 10+, there will obviously always be some, it’s this thing called realism, y’know). It’s also scaled up about 20x, as those little arrows are just too wimpy for us these days.
No, “look” is in the eye of the beholder and is subjective, so no it’s not a bug . . . it’s also intended behaviour so another reason it’s not a bug.
Add a feature request if you like asking for it to be “fixed” . . .
