I am using version 8.0.7. I used earlier versions and had no problem. When I connect two pads on different components and then move one of them using the click and drag method, the etch does not move with it. In previous versions, I am pretty sure moving the component did not break the connection. It kept the etch attached to the pad on the moving component. Am I doing something wrong or do I have a problem with my set up? I checked the documents and it said I should use “D” to drag the component, but that did not work either. Can anyone point me in the right direction?
I used to check for proper connection by moving the pad (component) around to see if the trace moved. I don’t know of any other way to verify connection. I guess from your comment, it looks like I am not making the connection. Is there a setting that says connect to the center of the pad? Am I setting up my parts in-correctly in such a way it prevents connection? Can they be set up that way? The footprints: U11 is an SOIC-8 and the resistor is an 0805 SMD. I had problems with all the part footprints. I removed KiCad and then reloaded it. I tried with a new project and different parts. Same problem. I sent a bug report in about it, but was referred to the forum. Is there an expert who can help with this?
Thanks for your help.
Yes, I tried both M and D and got the same result. I will have to look at the documentation to see if there is some set up I am not doing or has gotten crossed up. I used the default when I started up KiCad initially and for every project I worked on. This is something new as this is not my first PCB using KiCad.
OK, I will attach it here. I also tried making changes to a PC board that I previously designed and ordered thru KiCad. The same problem appeared on it.
OK, I got a message that said new users cannot upload anything. Do you have an alternative method?
