Q1: How does one install Ngspice into the Eeschema application on MAC OS High Sierra?
The topic similar to this describes how to install Ngspice in Windows or Linux only.
I did not know this was an option before I downloaded MacSpice (which seems to work with sample spice files),
but I have to generate the net-list file and save it, then input the file into MacSpice to run it. It would be good to run it within KiCad… like “talking to the horses mouth”.
I have just installed kicad-unified 5.0 today.
Q2: Can MacSpice 3 be installed the same way… ie, in the Eeschema app?
If Ngspice works better in this way I will use it instead.
My question again… “Q1: How does one install Ngspice into the Eeschema application on MAC OS High Sierra?
The topic similar to this describes how to install Ngspice in Windows or Linux only.”
If it is an integral part of KiCad, then why is there no mention of running simulations in the KiCad documentation?
Is this to be a surprise when completing a schematic capture?
I am not a computer programer, I am an aging electronics engineer who started on designing tube circuits without computer aids. I am now trying my hand at using the latest tools to make my own designs. I need step-by-step instructions of technical processes to install software.
Do you ask for support to do this? Then somebody else might give you the answer, because I am not on MacOS.
If you have installed KiCad 5.0.0 from the above web site, then ngspice extension to Eeschema should be readily available without further installation. Then you might have a look at http://ngspice.sourceforge.net/ngspice-eeschema.html, chapts. 2 ff. for an introduction (generating a small circuit, setting up the simulation, simulating and looking at the results).
I have installed KiCad 5.0.0 from the above web site… as I stated in my OP, kicad-unified 5.0 .
And I have just started my 1st schematic drawing on it. I always draw my schematics on paper 1st. Then draw them in a computer program to run a simulation. I have used Mouser’s MultiSim Blue on my Windows XP. I built the XP myself, and the XP still works without connecting to the web, but the MultiSim has “timed out”. Mouser no longer supports it.
Thank you Efcis, I’ll read the eeschema.html doc to see the initialization of the simulator.
Thank you holger, I am pleasantly surprised to find ngspice is included.
That makes me most enthusiastic (some may think spastic) to precede to learn this new technology. (Spice is new to old technical minds who cut their teeth on “suck it and see” prototyping.) KiCad must have old introductions to it in the “About KiCad” page that state this is only schematic capture and pcb layout software. I was given the impression that a spice simulator would be separate.
No. See https://bugs.launchpad.net/bugs/1780595 for details. It is Ngspice 26 for now. 28 will be packaged with KiCad version 6, provided sufficient adoption for it to be widely available.
Edit: Also, if you are interested in speeding the development of KiCad version 6 to have access to additional features, please consider a small donation here: https://givetokicad.web.cern.ch/
Thank you again Seth_h. I am considering to make a donation to KiCad via cern when funds are available.
The promotion of knowledge should be foremost on our minds.
