How to "Feed" the GPOLY Parameters Through The Schematic Symbol
Looking for what to try next.
EPOLY20230929_1005.zip (44.9 KB)
I am trying to use the G current source as a Poly.
From the ngspice manual at: https://ngspice.sourceforge.io/docs/ngspice-41-manual.pdf
on page 119 I get some examples which are hard to understand in terms of the schematic symbol fields.
Here is my schematic a sine wave into the G source with a load resistor.
I want to for example offset the output, have a linear term and a square term.
Here is my schematic symbol properties:
Here is the net list:
I think this should be making an output current which is not the flat line in this simulation.
I have uploaded the project as a zip file.
Poly sources are not directly supported by the Eeschema GSOURCE symbol.
The ngspice netlist does show
G1 CurrentOut 0 POLY (1) 3 0 0.1 1.0 2.0
which you have typed in manually (Sim.Params field).
As the manual states, the tokens 3 0 are nodes of a controlling source. But in your netlist node 3 is not connected to anything. So it is an open node, which leads to ngspice bailing out during simulation. With the RSHUNT option node 3 of the netlist will be connected to 0 by a resistor. Then the simulation runs, but with 0 V as controlling voltage.
So you have to figure out what the name of the controlling net might be, or you may give it a name by a label. Here is seems to be ‘ControlToO2’. Then you have to type in this name instead of 3, like
G1 CurrentOut 0 POLY (1) ControlToO2 0 0.1 1.0 2.0
(not tested)
Regarding,
BINGO That is what I needed to understand.
Now I have the part like this:
The net list like this:
And the simulation like this:
In this simulation the square term doubles the frequency of the input sine wave as expected.
TEN THOUSAND THANKS for seeing my mistake and explaining it to me.
Attached is the working simulation with the G1 POLY model.
EPOLY20231002_0752.zip (51.5 KB)
