How to change vias to the drilled pads?
Hi all, I have little problem. I’ve just created my first board in KiCad. But because it is “more difficult” PCB, i’ve done next layer, that will be used for connecting with simple wires, so I need to change all vias to drilled pads.
Is there some posibility to insert pad directly in Pcbnew instead of creating some fake component in schematic?
Great thanks for your help.
Just increase via size and via drill to your normal pad’s values and you’re good.
Great thanks for your advice Dolganoff.
I’ve changed everything according your advice (editing vias by pressing E) and I see that in the Gerb files after their generating (File >> Plot) everything looks just fine in the GerbView.
