I am trying to use the textbox in schematic to do certain things but can not find a documentation e.g.
.param Freq=100k
.param tau = 1/Freq
.param R = 3.3k
.param C=tau/R
print(C)
how to print values
change or assign values to capacitor, inductor or resistor
can somebody help, please
You will have to delve a bit into the ngspice capabilities (see the ngspice manual at Ngspice, the open source Spice circuit simulator - Documentation: manual and control flow, version 42), chapter 2.9 on parameters and 17.5 on commands in a .control section).
Attached you will find a project with parameters and printing a parameter (not into a text box, which is not (yet) supported by Eeschema, but into the simulator output).
params.7z (4.8 KB)
thanks a lot. This was very helpful. I understand that all data is available in
simulation → show Spice Netlist. This is composed of
- definition of probes
- content of textbox (my own program)
- Netlist from schematic
If values in the circuit in the schematic are to be changed/defined then this must be declared in the textbox as variable and will afterwards be used in the netlist (and it worked well in my example)
