I want to export my PCB layout to ordinary file, export to modify the layout in CorelDraw. Then print it on a transfer glossy paper, you know and then etching.
I started once with version 6. No problems to export to file SVG everything works fine. In 7 there was problems with no drill holes.
Now i 8 only one black rectangle.
In version 7 I had to use ordinary print and choose the PDF Adobe printer, made with Adobe print utility. Works fine but seems strange to use outside software to get a nice export.
In 8 plot to PDF I donât get the Edge.Cuts.
How to get a nice export file to import in standard software, CorelDraw?
It seems that it going in wrong direction for this software
Press print again and this will take you to your printer setup.
Check printer âpreviewâ to confirm everything is go, then print.
If you want a negative version, go through the same routine, but this time with the Plotter instead of the printer. The Plotter also has a negative version.
I cant use File > Export as I wrote in the beginning.
Because I make my own prints itâs really nice to use Corel. Then you easy can make curved shapes, place components exactly in the way you want.
I do a lot of high end amplifiers and the you canât use ordinary 45 degrees lines, you need to make everything smooth.
I use KiCad to have everything arranged in an easy way. You also have control over the connections between the components.
I think itâs easier to handle the print pattern in Corel when you are going to put it on the glossy paper for transfer to the copper
You are welcome if you want more information about the process.
There are technical reasons behind it or only artistic once?
In KiCad since V6 or V7 you can route tracks with rounded corners. There is a hotkey to change corner style, but I donât have KiCad here to find which one.
If that is so, then it is probably a bug that should be reported.
I just did: PCB Editor / File / Export / SVG and it exports a copper layer without problems. It also puts Edge.Cuts and the paper outline in the file.
When using PCB Editor / File / Fabrication Outputs / Gerbers / Plot Format: SVG I also get the expected result. When doing it this way, each file has the same info you would expect in gerber files.
Gosh, I never guessed that audiophools have degenerated to that level, but I guess you do what helps you to buy sandwitches. Are you aware of the âRound Tracksâ plugin from Mitxela? Yesterday I also mentioned it in:
Version: 8.0.1-8.0.1-0~ubuntu20.04.1, release build
wxWidgets 3.2.2
FreeType 2.10.1
HarfBuzz 2.6.4
FontConfig 2.13.1
Platform: Linux Mint 20.3, 64 bit, Little endian, wxGTK, X11, xfce, x11
Date: Mar 14 2024 15:11:44
Boost: 1.71.0
OCC: 7.6.3
Curl: 7.68.0
ngspice: 42
Please can you guide me to get the SVG file correct out.
Kicad 8.0.1 Windows 10, 64bit Pro.
I tried the plug in for filled polygons but when exported there was no fill in them, if I remeber right. It was also complicated to get the right shape.
I also tried the curvtool for the tracks between components with no luck.
Fastes to get the right look is to import the layout in corel. Unfortunately you miss the Gerber then but thath doesnât matter when you do the prints yourself.
Donât need soldermasks. Stady hand to apply solder.
If you like good sound over the usual then you need to make good layout for the PCB
As I wrote in the beginning I use PDF file now but itâs generated by an external software, Adobe printer.
Iâm still in V7.
For making my documentation files I export courtyard and copper layers as SVG. Then I import copper in inkscape, change its color to light gray and on this background I load courtyard picture.
I have never noticed copper layers being in any way corrupted, but I didnât tried V8 yet. I typically skip X.0.0, X.0.1 and may be X.0.2 when version X is released.
BlackCoffee
I really appreciate your video and engagement in my process. As I said before, it doesnât work realy good. In Corel itâs half the time and with perfect control.
As my questions was in the beginning, export SVG who was working in version 6.
I give up and.pleased with my print Adobe plug in for PDF.
Thank you for all support around my export problem
No. I have never even tried using Linux.
I have written that I have no KiCad here. It is because I write from Win7 PC and KiCad since V6 needs Win10. If I were using Linux I would have KiCad here.
I canât say anything about it as I have never used Print but always Export to SVG.
I am using v8.0 in Windows and everything just works, look at my screenshot to see which options did I used. v8.0.2 should be coming out soon, maybe give it a try and if still doesnât work do please file a bug report.
