How do I carry bus signals throughout sheets?
I have a schematic that contains several buses. I used local labels for each signal (such as a data bus).
This works great within the same sheet. But the design is starting to get large and I added a hierarchical sheet for other components that share the same bus. Obviously, the local labels don’t recognize the parent’s local labels.
I can provide pictures if needed.
How can I solve this without using global labels?
Take a look at bobc answer in Sending bus between sheets
This worked perfectly. Thanks!
