How can I resolve this solder mask error?
Whenever I run DRC I keep getting a lot of ‘solder mask aperture bridges items with different nets’ errors - I’m not sure what I’m doing wrong or how to fix this :frowning:
I’m using footprints that I’ve found online and when I check the gerbers in GerbView, the solder mask seems to be applied in the correct places on both sides of the board.
These are the first boards I’ve made and I’m a bit tentative to send them off for production after seeing these errors as I’m worried it will cause issues when I start trying to solder wires to the pads -
Any advice would be hugely appreciated please…!
These are the error messages I get when running DRC
Do you have a schematic ? was wondering why you don’t have any Nets ?
In any case this lack of nets explains the messages. Two items with no net aren’t part of the same net and are interpreted as belonging to different nets. A mask opening of a pad exposes the track attached to it.
Thanks both for the replies -
In this case would it be okay to go ahead and upload the Gerber files for production?
I skipped over making the schematic as the PCB doesn’t have any components - just some drill holes for attaching mechanical switches and some pads and traces for connecting the board to another board.
I did have a go but the tutorials I watched always had power supplies and resistors etc. and I wasn’t sure how to go about designing my boards schematic
Of course your board has components. Switches are components.
This is what you schematic could look like (quick and dirty):
Sorry my mistake - thanks for clarifying, would something like this be correct?
They are switches. Someone is going to push them, maybe often. You don’t pay extra for copper, so make the pads and tracks far more robust to cope with the use they may get.
Thanks for this! After creating this, is there something I can run to link it to my PCB design to fix the net errors?
Tools > Update PCB from schematic.
Although they are switches, each pin and each pad have a number. Those must match.
You may find after “Updating…” , your footprints may be reversed with respect to the symbols. In your case, because the PCB is complete, simply mirror the symbols to get the correct pad/pin associations, then Update again.
Sorry do you mean make the traces and pads wider?
Hopefully the pads for the switch mounts are okay, I took the footprint from github.
The pads are currently 1.524mm diameter pads with a 0.762mm diameter hole.
The traces are 0.35mm width - the switches will be getting a lot of use but I wasn’t sure if more than 0.35mm was necessary as the board will only be hooked up to 3.3V.
I can certainly make the pads and traces larger/wider though if that’s advisible
Yes.
Voltage and current didn’t concern me, it was the mechanical robustness and consequent life expectancy that troubled me.
Very small pads attached to thin tracks have a tendency to crack and break far more than big pads with fat tracks.
Thanks for the heads up, I’ll make sure I revisit this before exporting the gerber files again - would 2.2mm pads and 0.5mm tracks work? Or should I just go as large as I can whilst ensuring there is enough gap between traces and they are not too close to the edge of the board?
Would it be better to increase the pad sizes that the switches attach to or should I leave those be?
Increase both pads and tracks.
Thanks I’ve made everything a bit bigger now, thank you so much for your help! :smiley:
I think I’m almost there in terms of the schematic and nets issue -
However when I try and update the PCB from schematic it throws up errors about pads 3 and 4 missing?
missingpads
I spent a while trying to figure this out and noticed that there are 4 pins allocated in the symbol, so it’s throwing the error because I’ve allocated it to a switch footprint that only has two pins. I didn’t want to tamper with this and cause more errors:
Also when I select the left pin of the switch on the schematic it selects the top pad on the PCB so it seems like it has linked correctly, but it doesn’t do the same for the right-side pin and I couldn’t see a way to link it manually…
Left:
Right:
Sorry for being such a noob (and for the spam, I can only post one screenshot per message) -
I promise I’m learning a lot :sweat_smile:
