Hierarchical Sheets with picture
Is there a way to have a picture assigned to an hierarchical sheet?
In Matlab I can simply apply a picture to a “mask”, which is the equivalent to a hierarchical sheet in KiCad. IT looks like this:
grafik
I helps my folks to visually navigate though a hierarchical model.
Also back in the days as an ASIC designer I made an clear symbol for every subcircuit in my CADence circuits.
grafik
Is such a “property” of a hierarchical sheet also available in KiCad? It should be an easy thing to do? I can assign a background color to a hierarchical sheet, why not a picture?
I know that there is he picture to symbol converter and that I can “add” a symbol on top a symbol, but this is not a clean solution.
I really don’t like a schematic to look like a box collection.
Marko
Yes, and there are different ways…
  1. For an individual Schematic (or PCB), use the Add BitMap Image Icon (image does Not need to be BMP)
  2. For a WorkSheet that you can load into any project, Create/Edit a Worksheet and use the similar Icon in the Worksheet Editor.
  3. You can make a Template with the same process (can simply save a project with it to simplify …)
Below shows #1 and #2 with changing the current Worksheet with a Worksheet I just saved that has your creepy-crawly thing…
Thats not what I’m asking for. I don’t just want to have a picture in my schematic. I want to habe a picture in my hierarchical sheet “symbol”. Have you ever used Matlab Simulink and used “Mask → edit Mask → icon picture”? This is the ideal way of doing this.
Marko
There isn’t currently a method of doing what you’re after. You could add a feature request in gitlab for consideration if you’d like.
How do I do this?
Is there a link?
PS: Even just to “group” a picture with a sheet entrance would help.
