Hard lock-up with simulator (ubuntu 24, kicad 902)
I recently upgraded both my OS and KiCAD, as my old KiCAD (7) didn’t have the required simulator features I needed to run a simulation on my circuit.
I now have Ubuntu 24.04.02 and KiCAD 9.02 : release build.
After doing a variable number of simulations, my PC simply locks. Sometimes it suddenly goes really sluggish and then locks a few minutes later, and sometimes it just locks straight up.
I know changing both the OS and KiCAD simultaneously is a bad thing (the rule I normally stick to: change only one thing at once). Unfortunately my old OS (ubuntu 20.04) didn’t support KiCAD 9 out-of-the-box and I do not have the skills to compile or whatever it would take me above simply looking in the ubuntu software store… so I had to upgrade.
To try and get a grip on the problem I’ve done multiple other tasks with my PC without starting KiCAD, and it works flawlessly for days. If I load up KiCAD, even without anything else running, start playing with the simulator, I can pretty much guarantee a lockup within the hour (and usually it is less).
I don’t know how to diagnose this problem (perhaps it is a memory leak in the spice module?), and my current work-around is to save about every minute and just be prepared to hit the power button regularly.
Anyone else experiencing KiCAD 9.02 issues? Especially with the simulator?
At this stage I’ve only used KiCAD 9 Schematic & Simulator… my design is still WAY too young to think about layout.
Thanks,
MM
There is a lengthy discussion on the causes for memory overflow at Memory leak in simulation (#16404) · Issues · KiCad / KiCad Source Code / kicad · GitLab
A remedy might be to put the following onto the Eeschema canvas (it will remove all the output vectors of previous simulations):
.control
pre_destroy all
.endc
I wanted to delay my reply until I’d done some testing, and been running simulations for a couple of hours now (and keeping an eye on the memory usage). I think @holder’s suggestion has done the trick…
If something rude happens over the next couple of weeks, I’ll update.
(sorry, life gets in the way of playing circuits, otherwise I would have replied a couple of days ago)
Cheers,
MM
